MY NEW RX-7 AFTER A 8 MONTH PAINT & REBUILD
Re: MY NEW RX-7 AFTER A 8 MONTH PAINT & REBUILD
The rear end is a borg warner 4 11 28 spline steel billet axles lsd with holden commodore disc's and callipers all done by bosnjak engineering drive in & drive out $7500 aus all the RX-7 factory watts link all the shock brackets spring seats & sway bar brackets Bosnjak got the rear sway bar made to suit the car .As for the decal a mate of mine makes decal kits for all mazdas He is on facebook & ebay under the name Letzgo Rotary .cheers
also does the engine tune up guide and lube spec decals if you send him a sample of your decals he will make them up for you the english rx-7s might have different spec's printed on them as the tyre pressures decal
- 1004519_506596722747916_25026301_n.jpg (110.9 KiB) Viewed 2360 times
What a beautiful paint job and an unusal colour. Car is a credit to you - well done
