Agree. Talk to stacy.ian65 wrote:Stacy is the guy to talk to....... he's the one with the race car experience...
viewtopic.php?f=41&t=817
http://www.youtube.com/watch?v=fjsRambdFVk
I've spent a bit of time at stacy's. His car has been foam filled. More to stop crap getting in the chassi rails than anything though.
I assume you are/have seam welded the chassis?
The biggest problem I can see from your description is you will have the engine mounted so far forward (displacing the radiator to the back) that it will handle like a dog. You'll have so much weight over the front suspension.
To put in a four rotor I think you should be considering firewall modification.
How much power are you looking at? 700hp is readily achievable from a 13BT. I've thought about getting a 20B and putting it into something, but the cost just makes me grab a 13BT and think build that up with a nice turbo set up.
Have you seen the PPRE RX4 with the 6 rotor?
