Cricket
turntune
Cricket
Post by turntune »
Greeting from South Carolina, USA! As some of you have already viewed through my intro post, I'm deeply into what I'm now calling a "resto-mod" on my Series 3. For those that haven't seen https://www.facebook.com/media/set/?set ... 6b5f9233f3
as of 1-25-13
short day today, had family stuff in the afternoon. But alot accomplished, removed OEM exhaust, cut Y off header, removed all heat shields,removed blocks holding fuel and brake lines to the chassis, wire wheeled full length both sides (note to self- use a torch to burn out undercoating inside rails before welding) I stitched about every 4-6 inches from as far as I could from fire wall to the tops of the lower arm mounts in the rear, found rust through place in driver side frame rail- cut the worst out-treated with ospho while I stitched-re-enforce on both side rails then boxed it in with overlapping "u" section. Decided I'm gonna add the lighted driver door lock, Cricket is an "s" model so I've added all options from the "GSL" parts car I can and after a few repairs and a change to LED should work perfect!
1984 series 3 RX-7 "Cricket"
motor oil is not meant to be burned!
turntune
Re: Cricket
Post by turntune »
can anyone tell me why my 12a hosings are cast this way?
and not like the usual 1st Gen rx7 castings?
turntune
recent photo's
Post by turntune »
The rust I found before repair
frame rails prepped....everything exposed was stitched but still have a few places to do and ran out of time, next week I plan to drop the rear axle for the one of many times ( car has to remain a roller throughout build b/c of shop space) So I can stitch rear suspension mounting points and rear subframe then show finished product...
Re: Cricket
turntune wrote:can anyone tell me why my 12a hosings are cast this way? and not like the usual 1st Gen rx7 castings?
Not sure what you mean. They are S3 housings.
What do "other" FB housings you've seen look like for comparison?
turntune
Re: Cricket
Post by turntune »
1st photo is my housing which says "mazda motor corporation" I have a s3 with origional motor which is second picture and 2 other 12a's and all 3 say "toyo kogyo co. ltd" on top of rotor housings, was thinking newer castings were used.
turntune
Re: Cricket
Post by turntune »
Todays mission was to drop the axle, stitch suspension mounts front and rear, but after removing the tension rod mounts i found this
removed radiator, radiator support, wiring harness (going to do a tuck job anyway), and anything else inn the way and wire wheel it down
treated it with ospho and began to strip the front harness and tag everything and plan my routing for the tuck
favorite shot of the day....both my rides in one shot
lets just say i left rotaries to play with "leggos" but came back to big boy toys!
turntune
Re: Cricket
Post by turntune »
worked on wiring yesterday, started with this
started laying it all out, extending/shortening the engine wiring
then connecting to main harness
then tucking and hiding as much as pssible on motor, everything connected
then I started on the passenger side re-routing and tucking where and when I could and ended up with the next 2 shots
and overall passenger side
which leaves me on the driver side, holes are made where they need to be, pull wires ran, all I have left is extend a few then join the 2 harness' together!
turntune
Re: Cricket
Post by turntune »
here is what I've pulled thus far from the harness
turntune
Re: Cricket
Post by turntune »
shot of stock exhaust for placement and scale with new componants along side. laid it out to make a rough list for materials
cutting this y off to retain the duals
sound level-when needed- will be controlled with baffles here
center muffler is a super 44 series dual in/dual out but combines into one inside, like a x-pipe
turntune
Re: Cricket
Post by turntune »
and finally a few shots of the initial frame rail rust i found repair and the stitching
