First the one I bought one year ago, it was a good occasion to know what was inside for real and to start working on rotary engine.
So I started the disassembly process and ended with an almost naked engine
After that I ordered the 54mm socket needed to unlock the flywheel nut, so when I was waiting for it, I started to clean some pieces
The well known by all the rotary engine enthusiast, Blue Box of God
The intake manifold (pretty happy with the result
The oil pan (beurk!)
Air pump (why not, even if I don't put it back on, I was in a cleaning mood)
Don't have any pictures of the water pump cleaned
After I received my 54mm socket, I started the most exciting part
Almost there
Finally
But the rear was a bad surprise
Since that time, I'm still cleaning this rotor every month to make it looks better to have it as a decoration part. And I still have to take the measurement of all the other parts to see if I can fit them again (iron, apex seals, side seals, etc...)
Now back to present day, last week I get my hands on 2 12A's from Belgium, one was blocked and the other was turning by hand, so today I started to strip the blocked one (who is more dirty from the outside but I don't know for the inside)
The oil who came off the engine was not so dirty, but what stayed in the oil pan was !
And after a bit of work, I'm almost ready to open it
Now I have questions, how to know from which year is an engine ? I've seen the post with the flywheels shape and weight, but the flywheel from my first engine looks like a S2 but the last oil change is dated from 1981 with approx. 80800 miles... so probably an S1 with so much distance on it in this short amont of time ? Is there is another way to identify the exact year of an engine ?
