Ignition Coils
Has thanked: 5 times
Been thanked: 7 times
Ignition Coils
Post by DB RX63 » Wed Jul 25, 2012 9:50 pm
Chaps,
Another daft question from me, which I know you have come to expect !
OK, here goes, can I use any type of ignition coil on my S3 ?
i.e like these :http://www.demon-tweeks.co.uk/performan ... 84/2-3-1-1
Or are they a particular spec?
Tool will know..............
Cheers
DB
Has thanked: 0
Re: Ignition Coils
Post by RamoNZ » Wed Jul 25, 2012 10:12 pm
Anyone will do, without ballast resistor.
I would fit an FC coil pack myself and run waste spark on the leading plugs. I'm going to convert the RX2 to it but can't really do a write up until then, but plenty info on the net. Look for DFIS or direct fire ignition system. The diz just becomes the trigger to fire both terminals of the FC coil pack for both leading plugs And completely bypassing the diz and rotor arm which are subject to wear and an air gap etc - one rotor will be on the power stroke and the other acts like a third spark in the exhausting/other rotor chamber. win win all round.
You can then run one of these for the trailing, but not really worth it unless both originals are buggered.
*Edited to actually give a reason why you might do this :)
Has thanked: 0
Been thanked: 11 times
Re: Ignition Coils
Post by TOOL » Wed Jul 25, 2012 10:47 pm
What Ramondo said.
What's wrong with the Mazda ones? They're good units.
Listening to the cowbells
Has thanked: 0
Re: Ignition Coils
Post by TOOL » Thu Jul 26, 2012 9:35 am
Oh yeah, thanks for the vote of confidence, but Ramon and Tim are much better with leccy stuff.
I'm hopeless. :oops:
Re: Ignition Coils
Post by DB RX63 » Thu Jul 26, 2012 10:13 pm
Ramon,
You lost me I am a simple bloke.........
I am just looking at working my way through various things to update/replace and I was checking that a "standard" coil would be ok. You never know with a Mazda........
Has thanked: 0
Re: Ignition Coils
Post by TOOL » Thu Jul 26, 2012 10:27 pm
Search on Ausrotary. Lots of info on it there.
DFI ignition. FC coils are the upgrade part.
Has thanked: 131 times
Been thanked: 129 times
Re: Ignition Coils
Post by ian65 » Fri Jul 27, 2012 5:59 am
standard second hand fb coils are plentiful..... I've got about half a dozen lying about and 1st gens are being broken on a pretty regular basis nationally so getting a coil shouldn't be a problem if you ever need one
1986 Series 3 Elford Turbo viewtopic.php?f=4&t=2174
Has thanked: 0
Been thanked: 2 times
Re: Ignition Coils
Post by codge » Sat Jul 28, 2012 12:09 pm
Must be the most reliable piece of kit on any car.....that and the old points capacitor. The car shops used to say 'change this capacitor to protect against failure' But they never failed on me. A bit like PPI mis-selling......can we claim anything back after a zillion years?
kenwhiteside
Has thanked: 1 time
Re: Ignition Coils
Post by kenwhiteside » Fri Aug 31, 2012 2:21 pm
Can you run wasted spark on a rotary?
On at standard piston engine you would be sparking on the exhaust stroke therby burning any residues. Surely on a rotary engine as the rotors are out of phase you would be sparking when the point of the rotor was inbetween the two plugs. Is this a good idea? Probably burns up some of the trailing unbrunt gases i guess?
Has thanked: 0
Been thanked: 0
Re: Ignition Coils
Post by Lucky » Fri Aug 31, 2012 3:05 pm
They are wasted spark aren't they? :?
EDIT: at least, FDs are. I have to admit I haven't looked too far into the mysteries of the FB ignition system, mainly cos it hasn't gone wrong. Yet :lol:
