adjusting handbrake
RX_EJA
adjusting handbrake
Post by RX_EJA »
I know simply job i should know how to do it but cant see to find where to adjust it from, going to have a good look on the weekend would save me some time if anyone could give me some tips
Re: adjusting handbrake
Have a feel around the handle. There's a nut that fits over the end of the cable where it meets the handle tighten it and it will pull the cable up.
It should self balance, unless something is binding. You can grease the grommets under the car if it is binding.
RX_EJA
Post by RX_EJA »
TOOL wrote:Have a feel around the handle. There's a nut that fits over the end of the cable where it meets the handle tighten it and it will pull the cable up.
thank you, its just a little high and not holding to well on a hill
Yeah, just nip it up then.
unscrew the plastic cover from around the handbrake lever and you'll see the adjuster
If its not holding well I would be looking at the caliper end.
Make sure the levers on the calipers are returning to the stop when the handbrake is off, could be the lever siezing.
If it only needed adjustment it would still hold well but with the lever in a higher position.
RX_EJA
Post by RX_EJA »
thanks another job added to the list! getting abit pissed off now
