TWR spoilers and bodykits
Has thanked: 45 times
Post by ian65 » Sun Feb 26, 2012 8:12 am
I've noticed how some TWR bumpers and spoilers have TWR embossed into them and others don't and yet other wise they look the same. Anyone know why that is..... they must all be made by / for TWR surely.........
If the unembossed ones were copies by someone else, wouldn't they have to change the design to avoid all the legal issues?
Anyone got any thoughts on it?
1986 Series 3 13B Turbo II
Has thanked: 0
Re: TWR spoilers and bodykits
Post by TOOL » Sun Feb 26, 2012 10:30 am
Only ever seen the embossed ones.
Maybe the emboss has been lost if they've been repaired after damage?
Listening to the cowbells
Has thanked: 26 times
Post by KiwiDave » Thu Oct 04, 2018 6:44 pm
Has anyone successfully removed a TWR front? I'm sure it's not as simple as simply unbolting the bumper irons.
Does anyone know how the front kit attaches to the bumper?
Mine has has received a tap on the front left while parked. There's nothing that looks bent in behind so it appears that the whole assembly has shifted on the bumper so that it no longer is flush with the front edge of the wheel arch. This now limits the tire clearance when turning. It's not a big deal with the OEM wheels but anything wider and /or larger diameter is a big issue.
So I'd rather try adjusting it's position on the bumper rather than removing the whole thing. And I just know that screws and bolts are gonna break cos that's how these things go :roll:
Any tips, tricks, suggestions welcome.
Has thanked: 4 times
Been thanked: 6 times
Post by myatt1972 » Thu Oct 04, 2018 11:55 pm
I'll have a look at mine Dave, its currently up in the air with engine and rad removed, from memory I can see all the fixings of the bumper.
Post by KiwiDave » Fri Oct 05, 2018 2:55 pm
I've timed the question rather well then Keith th:
If you could get some pics, that would be awesome. I'm hoping that I can loosen the fixings to the bumper then move the whole assembly forward. A few screws and bolts need removing from the guard and wheel arch to allow movement.
Maybe it is actually easier to remove the whole thing,bumper irons and all. I just don't know yet.
Has thanked: 0
Post by Threesevens » Fri Dec 14, 2018 5:27 pm
TWR sideskirts up for sale on Facebook
https://www.facebook.com/marketplace/it ... 9884150771
Post by KiwiDave » Fri Dec 14, 2018 6:38 pm
They've been on sale for a while.
Has thanked: 0
Post by Threesevens » Fri Dec 14, 2018 9:01 pm
Cheers Dave hadn't seen them before
Has thanked: 14 times
Been thanked: 19 times
Post by spirit r » Sat Dec 15, 2018 3:43 pm
Some Pics TWR vs KÜWE front. I can see two fixing holes more on the TWR.(last picture) Hope you can get an idea watching these pics Dave.And Yes you have to remove the whole assembly.
Return to “RX7 Exterior”
