I read somewhere these cars do not like the newer pink/red stuff..........which is what I put in ours after the flush.
What is the issue and should I change it to blue or green? older style.
coolant/antifreeze
rustyrescue
- Has thanked: 1 time
- Been thanked: 38 times
- gt_james
- Has thanked: 114 times
- Been thanked: 211 times
Re: coolant/antifreeze
the pink stuff contains OAT which is an organic acid, I don't think the coolant O rings, and O rings in the intake etc will last long with that type.
I use comma super coldmaster ready mix as it has no borates, no 2-eha, no silicates and has phosphates in it. It's Ethelene glycol.
I know a few people on here use bluecol, but it contains borates.
never mix ethelene glycol and oat pink stuff.
- Been thanked: 188 times
A good indicator of the wrong type is the build up of Brown sediment in the bottom of the expansion tank which I believe is caused by Electrolysis. A reaction between the different metals in the engine.
my car has always been run on blue antifreeze and the cooling system is as clean as a whistle
- A7RXY
- Has thanked: 157 times
- Been thanked: 61 times
Remember Dave always spoke of his love for blue antifreeze
RIP our friend your car is in good hands.
