So the diff on my S2 needs a rebuild, noisy bearings & a lot of backlash in the drivetrain that I've now isolated to the diff. (got a fully recon driveshaft fitted with all new joints)
I already have the bearings for the axle at the hub ends, but I may as well do the whole lot.
I've hear lots about the diffs being almost identical to MX5s, although in my case 24 spline rather than 26.
https://bofiracing.co.uk/differential-r ... mx5-na-nb/
Unfortunately as usual finding a UK source for parts is difficult, will the bearings & seals & crush tube in the above link be suitable does anyone know?
Or even just the bearings & crush tube?
Rich
Is this MX5 Diff rebuild kit good for my S2 Diff?
rotarypower
- Has thanked: 94 times
- Been thanked: 71 times
rotarypower
Re: Is this MX5 Diff rebuild kit good for my S2 Diff?
Okay think I've sussed it:
- The crush tube I got from the MX5 website, according to Mazdatrix this is the same through til 92
- The side carrier bearings I also got from the MX5 website as according to Mazdatrix these are also the same NA through till 92
- The front and rear diff pinion bearings I got from UK Car Parts (who are not based in the UK ironically), I just plugged the Mazda number in and got the bearings they brought up.
- Seals I also got from UK Car parts by putting in the parts number.
Hopefully this is all correct but I guess I'll find out when I strip it down.
It would be so much easier if they published the bearing specifications / sizes etc as well as a parts number.
