1982 S2 Unidentifiable noise
Posted: Sat Apr 25, 2020 5:52 pm
Hi everyone,
I have a noise that I can't really identify what it actually could be, I hope one of you had a similar problem previously.
The car is 1982 S2 Euro spec completely stock with rear discs and open diff.
After 5-10 minutes of driving I get a really nasty noise. Sometimes it sounds like a grinding noise (almost as if the tyre is rubbing on the fender), another time it sounds like metal rubbing on metal. I guess it comes from the rear but I could swear it comes from the front sometimes too.
It occurs at any speed and only under light breaking or driving through a corner without any throttle input. I couldn't replicate the noise on the lift (warm and cold).
Here are the things that I already checked:
-The tyres aren't rubbing anywhere
-I don't have any play in the bushings, although they are starting to go brittle
-The wheel bearings run nicely and don't have any play
-The brake callipers aren't stuck, as well as the brake pads
-The rear discs had quite a bit of rust on the outer and inner edge, which I removed
-I changed the brake fluid, as well as the rear diff oil (which didn't have any metal flakes or pieces in it
-The exhaust isn't rubbing or touching anywhere hot or cold
-The diff sounds fine while turning by hand
The only thing I that could imagine, are rear axles rubbing somewhere, but I have no experience with a solid axle at all, so I don't know if this is even possible.
Cheers.
Ben.
Cheers.
Ben.
