84GSLSE 13BREW Swap build
DWNUNDR
Has thanked: 31 times
Been thanked: 22 times
Re: 84GSLSE 13BREW Swap build
Post by DWNUNDR » Tue May 14, 2019 6:24 pm
Might actually work out..
Before and after por15
These users thanked the author DWNUNDR for the post:
ian65 (Tue May 14, 2019 10:37 pm)
Has thanked: 131 times
Been thanked: 129 times
Post by ian65 » Tue May 14, 2019 10:38 pm
Wow, that's come up really well
1986 Series 3 Elford Turbo viewtopic.php?f=4&t=2174
DWNUNDR
Post by DWNUNDR » Thu May 16, 2019 6:09 pm
I spoke to early.. it failed.. sections started peeling and now I dont feel confident or want to risk running it..
So I am going to try again with the better tank thats is in the car currently.. but I will try electrolysis first, then go thru the por15kit.. I watched Aaroncakes video and after I realized it failed cause I rushed it...
Has thanked: 137 times
Been thanked: 74 times
Post by Hobbawobba » Sat May 18, 2019 6:49 pm
Ahh yeah. POR15 is very specific about how it needs to be done for it to work properly aye. Fingers crossed this next attempt works out :D
DWNUNDR
Post by DWNUNDR » Mon May 20, 2019 6:13 pm
Tank attempt 2.. changed the pot design... I made a test box to test the magnifier I got as my eyes suck short distance now being mid 40...
It worked.. I could see the puddle.. so I purged the tank and welded.. let it sit for 4plus hrs.. not one weep or drip...
Also patched the holes on my exhaust manifold as I am moving the wastegate outlets more inline with the exhaust outlets...
DWNUNDR
Post by DWNUNDR » Mon May 20, 2019 6:16 pm
Also the tank I had in the car was mint so I may not even seal it
Has thanked: 103 times
Been thanked: 79 times
Post by spirit r » Mon May 20, 2019 9:26 pm
Tank attempt 2.. changed the pot design... I made a test box to test the magnifier in 6jpeg8E48693B-1F06-452B-9608-CFB40C8669D4.jpegDAF4C722-3D4B-4829-972A-D24241706203.jpeg
Should be good having a drain plug, getting out the mud was building in that sump!
DWNUNDR
Post by DWNUNDR » Fri May 24, 2019 6:01 pm
Motor is back in
Gas tank is in
DWNUNDR
Post by DWNUNDR » Wed May 29, 2019 6:24 pm
trying to get done for my first car show on June 14th... currently working on the exhaust manifold modifications - cut the existing wastegate pipes off and am repositioning them in a more direct flow with the exhaust ports to try to eliminate some boost creep we were getting on the last motor..
PIA.. hahaha
Water-Meth setup should arrive today so then I have to install that as well...
ian65 (Thu May 30, 2019 11:08 am)
DWNUNDR
Post by DWNUNDR » Thu May 30, 2019 6:17 pm
Got the exhaust manifold done and in.. everything I welded screwed the next thing in the line up... haha so pretty much redid the whole wastegate setup almost
