84GSLSE 13BREW Swap build
DWNUNDR
Has thanked: 0
Been thanked: 2 times
Re: 84GSLSE 13BREW Swap build
Post by DWNUNDR » Mon Oct 15, 2018 6:00 pm
Has thanked: 9 times
Post by Casey » Tue Oct 16, 2018 5:08 pm
Are these seats with electric seat adjustment and seat heaters? If so, it would be great to hook them up :D
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Tue Oct 16, 2018 6:21 pm
yes.. I plan on getting power to the adjuster motors but havent decided on heaters... not sure I want to be driving this in winter hahah
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Mon Oct 22, 2018 6:03 pm
little more wiring done... issues with pump trigger now so I will bypass it with a switch...
got the wideband mostly hooked up now and ope to figure out how to power the drivers seat soon now that the mount worked perfectly...
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Tue Oct 23, 2018 12:39 pm
decided to go ahead and take a chance on the changes I had made to the design of the drivers mount.. tape measure measurements and guesses on the changes and voila... almost sits flat.. it is about an inch higher on the passenger side once seat is on the mount.. tonight I should finish up welding the seat to the mount...
Has thanked: 8 times
Post by ian65 » Fri Oct 26, 2018 9:42 pm
nice work on those mounts h[b[
1986 Series 3 13B Turbo II
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Sun Oct 28, 2018 1:34 pm
thanks
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Tue Oct 30, 2018 11:40 am
Figured out the power to my driver seat last night.. not using the heated seat part just the movements...
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Tue Nov 20, 2018 6:15 pm
gave up on waiting on mates who are busy... so started bodywork and paint prep
DWNUNDR
Has thanked: 0
Post by DWNUNDR » Mon Nov 26, 2018 12:55 pm
after some work being done over the last week or so I got to my doors and discovered my ds door was bent... didnt want to spend $100+ on a tool for pulling dents so I used some bolts, some heat and a vice grip haha.. minimal bondo used despite what it appears... it has to be sanded down yet
Image Image
Image Image
Image Image
