KIMI 2 - 1983 Series 2
Has thanked: 84 times
Been thanked: 73 times
Re: KIMI 2 - 1983 Series 2
Post by Casey » Sun Feb 17, 2019 6:24 pm
Nice weather today for a short trip to take KIMI 2 to a local car show alongside the river Colne :)
Good to see another rotary turn up too, a 2004 plate RX-8 (forgot to take a pic of it though :oops: ).
Pic 3.jpg (148.7 KiB) Viewed 988 times
Pic 1.jpg (178.49 KiB) Viewed 988 times
Pic 2.jpg (144.25 KiB) Viewed 988 times
KIMI 3 : 1st Gen, 1983 S3
Has thanked: 137 times
Been thanked: 74 times
Post by Hobbawobba » Sun Feb 17, 2019 6:56 pm
Decent day for it aye! That's a cool location too :D
Post by Casey » Wed May 15, 2019 1:15 pm
I had the front, passenger-side brake disk getting a lot hotter than it should, so took off the caliper and found the sliding bolt was bent and the piston seized :( . I pumped the piston most of the way out using the brake pedal, with a block of wood in situ. I then removed the caliper from the car, hoping to get the piston out the last bit with an airline. Nope, 8 bar wouldn't shift it :( - I ran out of time and will give it another go tomorrow.
The caliper looks manky too, so some cleaning up and a rebuild is in order. I did the other side some time back;
viewtopic.php?f=4&t=2989&hilit=caliper+rebuild&start=14
I have another rebuild kit and some VHT paint, so hoping the piston is in reusable condition, when I get it out. Will either have to put the caliper back on the car or cut off the dust boot and squirt some penetrant around the piston in the hope that will feel it enough to air-blow or wiggle it out!
Meanwhile, I need to get some replacement sliding pins. This is from the rear of KIMI 1, so I need both front and rear. I haven't put them side-by-side, so not sure if they are the same, or not.
Any advice, and sources for the sliding bolt would be most welcome (and piston source, should it come to that)!
Has thanked: 131 times
Been thanked: 129 times
Post by ian65 » Wed May 15, 2019 5:06 pm
bloody hell that slider bolt look like it's been at the bottom of the sea :shock:
These users thanked the author ian65 for the post:
Casey (Wed May 15, 2019 7:23 pm)
1986 Series 3 Elford Turbo viewtopic.php?f=4&t=2174
Has thanked: 54 times
Been thanked: 83 times
Post by DKWW2000 » Wed May 15, 2019 7:12 pm
A seller like this one may help helpful & you can give them the size etc:-
https://www.ebay.co.uk/itm/Rear-Brake-C ... SwEK9UCxIx
These users thanked the author DKWW2000 for the post:
Has thanked: 5 times
Been thanked: 7 times
Post by DB RX63 » Wed May 15, 2019 8:45 pm
Try Big Redd, I think they carry spares ?
These users thanked the author DB RX63 for the post:
Casey (Thu May 16, 2019 4:16 pm)
Post by Casey » Thu May 16, 2019 5:10 pm
Thanks guys, the only possible source I was aware of was Bigg Red. I used them to refurb a pair of rear calipers for KIMI 1 a couple of years back. I've just shot them an email enquiry.
I finally got the piston out :x I had to put it back on the car and stamp on the brake pedal a few times, nothing else would shift it! Can't detect any pitting on a quick look at the piston, so will clean off the staining with 1500 emery and re-check. Caliper bore looks OK, so will clean and paint as I can'r put it back on the car looking like that :oops: :)
Image[
These users thanked the author Casey for the post:
ian65 (Thu May 16, 2019 5:23 pm)
Post by Casey » Thu May 16, 2019 5:23 pm
Oh dear, Bigg Red have replied:
"Hi there, Thank you for the enquiry but unfortunately we cannot help with these sorry.
They are very difficult to source. We have known people have to make new ones to fit."
:shock: That's a surprise - if these guys can't get them, that's a little concerning. Surely these bolts are not unique to this car model, or even Mazda?
Any other ideas? ...or maybe I'll have to find a local machine shop who may able to make some....
Post by ian65 » Thu May 16, 2019 6:03 pm
Casey (Thu May 16, 2019 7:49 pm)
Post by Casey » Thu May 16, 2019 7:49 pm
Thanks Ian, worth a punt, I'll let you know.....
