When I bought the car I drove back 200 miles from Somerset stopping on the way and the car restarted fine.
I drove it for three or four days and it started first time every time.
Then the starter motor failed but I was able to start it easily with a bump start.
Then I had the service, the starter motor worked and the she started but wouldn't idle. I had the same problem before the service.
The mechanic tried to adjust the idle screw but that didn't seem to help much and couldn't get it to settle at 900 revs. Previously after a run it would settle at about 900 and not cut out.
The mechanic left and I tried it a few minutes later but it would not start. I tried to bump start it but she wasn't having it.
This morning the mechanic returned saying he thought the engine might be knackered as she is giving off some white smoke. He said it might be compression issue and that is why it wont start.
He tried a compression test but I am not sure the results mean anything when a standard tester is used. The results were about 75 for each but I don't know what this means. Also because she wasn't able to start the tests were taken on a cold engine. The engine might be worn as it has done 68k miles but I don't think this is causing the non-start issue.
Eventually we put back the old plugs and they looked the same but had a slightly different number although both sets are NGK
After squirting a little oil down each cylinder and some spray through the air filter intake she did start although would cut out if you let the revs drop.
She wouldn't restart unless we squirted more spray through the air ilter intake.
It would run all day if you kept the revs up at about 2500 revs but as soon as you let them drop she would cut out.
The mechanic has left and of course it won't start. He is trying to take guidance from someone else and return early next week. He is not familiar with rotary engines but is a well known trusted bloke but has probably reached the end of his knowledge.
He still thinks it is related to compression but I find that hard accept as it started on the button everytime before the starter motor packed in. I feel it is carb related as it starts with the magic spray squirted in to the air filter in take.
Can anyone help as i don't seem to be getting anywhere, literally!!
Kevin
