Page 1 of 1
Series 2 diff / axle?
Posted: Thu Sep 22, 2011 10:22 pm
by Johnnyboy
Hi guys.
Funny noises coming from miss January's back axle.
Anybody got a good s2 diff for sale? Or perhaps an entire axle?
John
Re: Series 2 diff / axle?
Posted: Thu Sep 22, 2011 10:33 pm
there's a s2 being broken in Banbury John.... I've bought parts off him and so has Keith
viewtopic.php?f=32&t=228
Posted: Thu Sep 22, 2011 11:16 pm
by Johnnyboy
Thanks Ian.
I will give him a ring tomorrow.
You remember I mentioned on Monday that it was whining? Well it is now making graunching and even ringing noises - so I think I had better do something about it fast.
As you know I was talking about "engineering" a hybrid axle, based on a S3 axle but with S2 brakes and Hubs re-drilled for 13" (ie. S2 110mm PCD) wheels and an MX5 LSD. However I appear to have run out of time - unless someone out there with an engineering shop can build such a hybrid for me....
John
Posted: Fri Sep 23, 2011 12:06 am
by myatt1972
ian65 wrote:there's a s2 being broken in Banbury John.... I've bought parts off him and so has Keith
Decent guy to deal with, he helped me load an engine into the back of my car and then made me a cuppa!
Posted: Fri Sep 23, 2011 5:07 pm
by rx-7 chris
Johnnyboy wrote:Thanks Ian.
John
It isn't as easy as just having it redrilled for 110mm. The S3 axles stick out farther than the S2 axles because the axles are actually longer. The actual housing has the same flange so the calipers will bold right up. If you could get a set of US spec non SE S3 axles, than it would all bolt in easy. You could also get a set of Moser Axles.
http://mrcmfg.com/catalog/product_info. ... db6ba4c520
I can explain it more if you would like.
Posted: Fri Sep 23, 2011 8:50 pm
Are you desperate to keep the 110 PCD?
