Just a quick check if anyone might be interested in a complete FC front end for the purposes of fitting to an FB.
The subframe is not a bolt in job by any stretch but once you know what you are in for then it's not bad - I can give advice if this is something you are interested in.
The subframe is compete with a manual power steering rack - very easy to upgrade to a power rack due to most FCs having these.
Also includes:
Ferodo DS3000 pads and cross drilled discs - less than 2000 miles
Turbo 2, Aluminium 4 piston calipers
Braided brake hoses
Complete FC steering column.
Car is still whole at this stage, so the steering and brakes (and bushes etc..) can be test driven to see what they feel like and compare to an FB. I also have my FC converted FB available so you can see how things go together.
£175 - pick up from TN22
