cooling system refresh....
Has thanked: 0
Re: cooling system refresh....
Post by TOOL » Tue Jan 14, 2014 9:33 pm
I can't remember for sure.
Here's a 13BT I bought last year. Proper goosed.
They're not the same but it's been a few months since I did this on a 12A.
You can get any gaskets you need from Mazda easy enough so give it a go.
Listening to the cowbells
Has thanked: 0
Been thanked: 2 times
Post by codge » Tue Jan 14, 2014 9:34 pm
richrx wrote:
TOOL wrote:
PS I'm not Codge lol
lol my apologies. ... who did I insult most? :p
TOOL I would think......he's the tech guru.
Has thanked: 0
Post by TOOL » Tue Jan 14, 2014 9:45 pm
I wouldn't go that far lol. I've just sent a few to the scrappy in my time.
Of course you can take the water pump off. You install the water pump after assembling the block.
Here's proof (S1 motor I got some good housings from)
New baby = lack of sleep :oops:
richrx
Has thanked: 4 times
Post by richrx » Wed Jan 15, 2014 11:03 am
Thanks for the pics, the 13b looks bad, butbi fear that how mine will look internally :( also on the 12a it looks like the main pully is smaller than mine... maybe just the photo.
Anyway I'll get it off next week, untill then I have a box of goodies to clean up, including that imlet manifold :) hopfully the engine, engine bay and ancillaries will look much better after a daynor so of degunking :)
richrx
Post by richrx » Fri Jan 17, 2014 5:05 pm
Sorry guys another photo and another question. ... is this usable the damage seems to be below the gasket that was on... also what are the holes that appear to be gummed up for? Their triangular in shape...
Thanks again..
Has thanked: 0
Post by TOOL » Fri Jan 17, 2014 6:59 pm
That looks pretty corroded. As long as you can seat a gasket it should be fine, but it's not like the manifold wears so you should be able to pick up a good replacement for peanuts/free.
The bits you're referring to between the ports are supposed to be solid. That's just crud build up on top. Ignore it.
richrx
Post by richrx » Thu Jan 23, 2014 4:44 pm
Woop woop, finally got round to removing the water pump and housing.
The pump came out first, then I had to remove the studs from the block and pull the housing off. Going to clean it all up and get it back on... the pump looked fine 100 times better than any of the bmw pumps ive ever changed!!
richrx
Post by richrx » Mon Feb 10, 2014 4:13 pm
Hi
Heres a question that I saw coming. .. has anyone got the part numbers for the water pump gasket,water pump housing gasket and thermostat gasket? Hoping to get the engine into the car and get it running again by march :)
I did find part numbers on the mazdatrix site but they seem to be in the wrong order and mazda do t recognise them.
Has thanked: 49 times
Been thanked: 43 times
Post by ian65 » Mon Feb 10, 2014 5:10 pm
Have you got a copy of the series 3 factory parts catalogue Rich?
viewtopic.php?f=30&t=131
1986 Series 3 Elford Turbo
Arvika
Has thanked: 0
Been thanked: 0
Post by Arvika » Mon Mar 03, 2014 9:29 am
I always do it in a different way when I get a new car...
The first thing I do is to put two "tablets" for a dish-washing machine in the radiator.
I drive around for an hour or two like that, just to make sure it cleans the hole system.
After that, it's time to flush the system properly...
I empty the radiator and the engine. (do not forget the plug on the middle iron)
Then I rinse through everything real well with a garden hose.
After that I fill up with only water and run the engine for an hour again.
New drain and rinse ...
And after that the final fill with a 50% mixture of distilled water and antifreeze!
Lars Bodin. Stockholm, Sweden. 2 x Mazda Rx7 1985 + Mazda 1300 1975
Return to “Cooling”
