It's an 85 GSL-SE with 195,000 miles.
The car has has some issues... I've got my work cut out with this one. For example, this is the kind of shoddy wiring I've got to contend with...
My buddy just recently rebuilt the engine and we just got it running the other. I plan on some pretty extreme modifications. I'd like to make it a caged, widebody, semi-racecar. But that will be sometime down the road. I'll work up to that, but for now I am gonna keep upgrading it slowly, learning more about the car as I go until I'm familiar enough with it to plan the big projects better.
I'm very fond of driving, so you can be sure I will be using this car on the street (and probably the track too eventually) as much as possible.
On the sooner-than-later to-do list:
-Replace blown illumina shock (shipped defective)
-Install Poly bushings
-Fix shoddy wiring/electrical gremlins
-Install speed-bleeders, overhaul brakes. (eventually upgrade pads/rotors)
-Fix strange 'clanking' sound from somewhere under car when releasing clutch
-Fix vibration from rear end. (Gonna upgrade to Kia Sportage gears)
