Alloy rad
kenwhiteside
Has thanked: 2 times
Been thanked: 21 times
Alloy rad
Post by kenwhiteside »
Hi,
Anyone using an alloy rad such as the below
http://www.ebay.co.uk/itm/MAZDA-RX7-RX- ... 2a1ec2b962
My current rad is looking a bit scabby and I am a bit worried that it will leak and leave me high and dry.
The other option would be a stock part either new from mazda (if avaliable) or a refurb.
Tim
Steve-A
Re: Alloy rad
Post by Steve-A »
I bought a cheap eBay Chinese Alu radiator. It arrived slightly bent in the post, and the quality of mounting brackets didn't look great (though I didn't really use them as I bought an FC radiator to retro-fit to my FB).....
BUT it held water and cooled it well. 18 months of daily driving later when I sold the FB it was still doing a great job. They are cheap, so you can't expect them to be perfect but I don't think they're a bad option at all. :)
Re: Alloy rad
Don't you mean 'hot and dry' Ken?
Refurb is good and easy. Many radiator recoring specialists still working around the big industrial centres.
A new matrix with the the original headers refitted and then the side plates on and it's good to go.
A waft with black glossy, a new cap and it's factory fresh again.
Mine was £100 about 8/9 years back.
Dave
Re: Alloy rad
I had my S3 rad recored last year. Cost about £100. Much thicker core and 2 row. Better all round.
That Chinese stuff is junk imo. You never know what you'll get till it arrives.
Bear in mind that S1/2 is different to S3 (S3 is full face due to the beehive).
His title is misleading for a start.
mpk490p
Re: Alloy rad
Post by mpk490p »
pretty sure Shaun had a jap rad that was a waste of money not sure if its the same seller though
95 FD RS in black
Re: Alloy rad
I would spend the monies on a recore. That way you know the dimensions will be right and increase the cooling with more cores.
I have used these guys in the past and they offered a great service. A bit far from you I know but they do courier.
Express Radiators Services 02086701419 - their website is not working at the moment?
kenwhiteside
Re: Alloy rad
Thanks guys, will steer clear of it and get the current one recored.
Tim
Re: Alloy rad
codge wrote:Don't you mean 'hot and dry' Ken?
Dave
Sorry Ken, they waft the black glossy, you don't have to.....my poor paragraph structure.
Re: Alloy rad
I let do that 20years ago with a speziell radiator race block and find it´s a good way to get a better cooling with a S3 rad. I also take two oil cooler.One aircooled and the other one watercooled.(the bypass valve from the watercooled oil cooler open first and help for quicker warm up the oil)
Return to “Cooling”
