Racing beat oil cooler hoses New
hotdog
Post by hotdog »
Hi all,
I have for sale a set of new, never used, Racing Beat oil cooler hoses as per the photo.
£80
Cheers,
Toby
Re: Racing beat oil cooler hoses New
hi Toby, do you know if these hoses will work using a FC oilcooler on a FB ? or does anyone else know /
hotdog
Post by hotdog »
It depends where you want to mount your oil cooler. They will work as far as thread size in concerned but you might be better of buying custom hose and running the cooler further forward. Its up to you. These are a direct replacement for the standard hoses.
Thanks Toby I want to mount it in front of the rad, I thought they would be too short.
These do not suit FC oil coolers. FC has different fitting to FB.
You would have to purchase adaptors to make it work.
Here's an FC oil cooler:
hotdog
Post by hotdog »
Thanks for posting the picture it helps to explain. Yes you would need to purchase adaptors for the oil cooler you are using. Speedflow or Earls can supply you what you need. This sale is for the hoses only.
Rexi84
Post by Rexi84 »
pm'd
'Dont fear the rotor'
hotdog
Post by hotdog »
Sold
Return to “Parts For Sale”
