Page 10 of 34
				Re: 84GSLSE 13BREW Swap build
				Posted: Tue Sep 04, 2018 6:38 pm
				by DWNUNDR
				Posted: Wed Sep 05, 2018 2:41 pm
				by spirit r
				I hope the very long battery cable having the correct Cross section. The Yellow top 55AH needs 14,6 V for full load. Btw nice pictures!
				Posted: Wed Sep 05, 2018 6:05 pm
				by DWNUNDR
				its 4 gauge.. more than enough...
				Posted: Thu Sep 06, 2018 12:57 pm
				by DWNUNDR
				Posted: Thu Sep 06, 2018 7:00 pm
				by Hobbawobba
				Bet that felt good!
 Nice progress. Can't wait to get mine cranking haha
				Posted: Fri Sep 07, 2018 12:30 pm
				by DWNUNDR
				yes but no haha... Yes cause it was awesome.. No cause.. well no signal to the coils or injectors..
buying a cheap laptop today off of a mate so we can see what the ecu sees...
				Posted: Tue Sep 18, 2018 6:09 pm
				by DWNUNDR
				oil cooler fittings were cracked and I missed them... so I fixed them...
I think..haha
				Posted: Wed Sep 19, 2018 12:39 am
				by KYPREO
				Unfortunately they are quite prone to cracking, mainly due to the force that placed on the bosses when removing the banjo bolts. If they crack again, I strongly recommend looking into an FC oil cooler. These having the fitting top and side to prevent this from occurring.
DWNUNDR wrote: ↑Wed Sep 05, 2018 6:05 pm
4AWG wire usually has a current carrying limit of 60 to 100A (depending on who you believe).  While that is generally OK during normal engine running, current draw can spike well above that during cranking (200 to 250A).  Also, the fact that the wire is several metres long means you can experience voltage drop from the alternator even across 4 gauge. If you have an EFI system with fuel pumps, multiple injectors and a thermofan, you could easily exceed 60A under some conditions, which would push 4ga to its limit.
For these reasons, for the main battery positive cable, I was recommended to use 70mm stick welding cable or 00 automotive cable with a 250A breaker. After my 4ga starter wire melted, I upgraded from 4ga to this stuff, using a plated pass-through terminal on the chassis floor, and it was a million times better. 4ga wire is really only for big stereo amplifiers IMO.
Lots of great info on the topic here:
http://www.ausrotary.com/viewtopic.php?f=16&t=31504
				Posted: Wed Sep 19, 2018 1:12 pm
				by Hobbawobba
				That link posted above is the holy grail of wiring up the battery really
 . Has all info needed. I also went with 70mm2 cable. Oceanflex brand tinned stuff which is super flexible for its size, 200A breaker and a through panel to the starter
				Posted: Wed Sep 19, 2018 4:38 pm
				by codge
				Yep, Butyl Hypalon welding cable, 70mm2 sounds right.
You need loads of amps and lowest possible volt drop when starting.
I've designed many a mains switchboard and generator starting panel using this stuff.
Crimped or soldered lugs would terminate the cable nicely.
