Page 9 of 14
				Re: My New (old) rx7
				Posted: Thu May 07, 2015 7:07 pm
				by marked
				TOOL wrote:Check for spark at the plug as per above.
Check for fuel at the carb. Pull the blue lid off. Look down the carb while pulling on the throttle lever. You should see 2 jets of fuel coming from the accelerator pump jets.
Check fuel filter. Check fuel pump function.
A fully charged battery will help crank it faster.
Report back.
Hi TOOL,
I've got the lid of and can smell petrol, where can I find the throttle lever to see if any fuel is coming out?
I can hear the pump running, no idea if it sounds as it should though. Also, I never emptied any old fuel that might have been in there - but I thought that the small bit of fuel straight in to the carb would cut out whether it was a fuel delivery issue?
What do you recommend as a battery charger - I got a maypole one but it doesn't seem to work, just keeps telling me it's not connected correctly (when I'm pretty sure it is!!
				Posted: Thu May 07, 2015 8:36 pm
				by marked
I tested the bottom and top, it looks like bottom is getting spark, I couldn't tell on the top as it was too light to see, I'll try again shortly as it gets dark to see better.
There seems to be something missing from the engine bay aswell, lots of cables in the corner not attached (see photo).
am I missing something major in the corner?
I've checked all plugs now and the tester light blinked on all of them, so I guess that's passed... what do you guys think I should try next?
				Posted: Thu May 07, 2015 9:22 pm
				by codge
				I've not got any items in that corner of the engine bay......but no free floating connectors either.
Why should the battery charger be indicating incorrect connection? Need to investigate that by trying on a friend's car before buying another.
				Posted: Thu May 07, 2015 9:38 pm
				by A7RXY
				Marked where in London are you ?
				Posted: Thu May 07, 2015 10:20 pm
				by marked
				codge wrote:I've not got any items in that corner of the engine bay......but no free floating connectors either.
Good point codge, I'll try it on my daily driver to check - didn't even think of that!
				by marked
				A7RXY wrote:Marked where in London are you ?
Catford/Grove park - Near Lewisham.
				Posted: Thu May 07, 2015 10:31 pm
				by A7RXY
				marked wrote:A7RXY wrote:Marked where in London are you ?
 Sorry i don't know anyone who is that close to you who can help.
				Posted: Thu May 07, 2015 11:08 pm
				by myatt1972
Nothing missing, I also have those spare connectors.
				Posted: Fri May 08, 2015 6:41 pm
				marked wrote:Hi TOOL,
The throttle lever has the throttle cable attached to it. Not the choke cable.
Pull the fuel line off the carb and run fuel into a bucket or something to make sure it's flowing properly from the pump.
Try a CTEK battery charger. That's what I use.
				Posted: Thu May 28, 2015 9:18 pm
				by Robsrx7
				How's this one going any joy with it yet
