So whats happened over the weekend and into today... I got the fuses and relays wired up in the glove box and the Megasquirt mounted. Wiring will be wrapped and green tape gone once I know it all works!
All sensors are reading sensibly, and the ones I can test without running the car are responding. I had a bit of a scare when I got no crank position signal initially but it was a dirty connector, which was a nice simple fix.
I've still got to wire up my wideband controller, the Megaview and my oil temp gauge. I'd had enough wiring for now anyway so decided to work on the fuel system. First up I got the engine bay side all connected up which was pretty simple.
After lots of thought I've decided to mount the pumps and swirl pot in the spare wheel well. I will make a metal over this and seal it down so I still have a fire wall between me and the fuel system (and it it will reduce the petrol smell in the cabin I guess) but this way the pumps should be safe from the elements and easy to get to for maintenance. I've got everything but the return from the fuel rail connected up here.
While I had the back of the car up in the air I decided to tackle the rear axel. As you can see it doesn't look so shiny after 6 months of use and plenty of salted road action.
I've got two niggles with the rear axel. The first is just cosmetic, with my GAZ coilovers in the rear I've currently got to run with about a 30mm arch gap to give me a sensible amount of negative suspension travel. So I'm going to add an extra mounting point for the coilovers so I can run the same suspension travel but drop the rear of the car down so the arch gap matches the front.
Secondly she's always pulled a bit left, and shortly before I took her off the road I took her to have the suspension alignment checked out. The front was running a bit too much camber, but was essentially ok, the rear axel on the other hand was almost 1/2 a degree out of line, causing my left pulling. I broke out the calculator and dredged the back of my head for some trigonometry knowledge and decided that one of the mounts must be ~7mm out of position :s
When I first got her I could put my hand through the strengthening plate that held the mounts on the chassis side square, so whilst I was careful not to move them when welding I guess the damage was already done.
At this stage moving the mounts on the chassis really isn't gonna be practical, so I'm going to move the mounts on the axel. Well more specifically a mount on the axel! I've made up a new mount with a cammed bolt set-up that will allow me a total of about 8mm adjustment and I plan to weld in place of the old mount, offset by that 7mm I've calculated. With a bit of fine tuning she should be nice and square now.
With some luck the next update will include a video of her running!
