Building an RX7 LSD diff
Re: Building an RX7 LSD diff
Yes LSD. Busted to hell. Probably B series truck / Ford. No way T2.
				Rubarotary
Indeed one is Just scrap metal but the second one is ok but if i could find axles to match And Same witdh of An rx7 would this be An upgrade ? I now Have a standard lsd.
Thanks For the help, great info on the thread btw.
8 inch will not fit FB.
Why do you want to change your LSD?
				Rubarotary
I'm thinking about putting a 13b Turbo in but since i've been told the original lsd would only hold about 250hp i'm afraid i'm gonna Break it.
If i could find a possibility to upgrade the front brakes without having to fabricage something i would stick to the 12a.
I've been looking to put some fc brakes on but since it al has to look somewhat original For ( what you call mot ) .
But Back on topic that's the reason why.
T2 engine is only 200hp. The S3 has thicker axles which is a weak point in the earlier cars. The diff is probably next in line, but they're good units. It's torque and driving style that kills them.
Go easy on it and it will last.
To upgrade you'll need to change the whole rear end.
				Rubarotary
Ok i'll give it a go with the one i Have, but if i do need something stronger i'm guessing i'll Have to go with a Ford axle or something?
Thanks For All the advice so far
- Has thanked: 476 times
- Been thanked: 253 times
LSD 26 spline 4,1:1 ratio all new bearing and sealing included and post to germany Andy?TOOL wrote:Sunday night bump on this.TOOL wrote:If anyone else is interested in a lower ratio ring and pinion for their diff, let me know and I will keep searching. It's been a lot of research and some trial and error, but I'm starting to get results.
Let me know what ratios you want.
Not any time soon.
The bearings aren't cheap either.
4.1 comes from an MX5. Easy to get.
Only for the CWP really.
