Lucky's Series 3
Re: Lucky's Series 3
you should be working for mazda mate, with teaser posters for any new models they are bringing out
lol, I don't think they want the sort of P.R. that says "Mazda Rotaries; you'll kill at least one set of plugs just trying to start the sodding things"
I've gone all inappropriate before bedtime
And where are the vacuum advance hoses connected to or is that photo trickery??
aha, therein lies a story...KiwiDave wrote: And where are the vacuum advance hoses connected to or is that photo trickery??
*cough* they're not. Currently. *ahem* nothing to connect them to.
 Does make it a real pig to start just now. Working on a solution to this li'l conundrum
  Does make it a real pig to start just now. Working on a solution to this li'l conundrum-
You typically don't run the vac advance (or OMP) with an IDA.
Don't see why you can't run the OMP, all it needs is a linkage. Can't really run vacc advance as the carb doesn't support it. One of the reasons I wanted a Holley in the first place. Choke would be nice, too...
can't you tap it off the manifold?Lucky wrote:Can't really run vacc advance as the carb doesn't support it.
Don't know. Would it not fluctuate really profoundly then? There is a plan underway, but I won't say too much in case it turns out an epic fail. Lol
mine comes off the inlet, between the carb and the compressor, right next to the take off for the brake servo..... can't imagine yours being any different really, no turbo but same principle, just a line tapped into the inlet
