C160SFG - 1986 Series 3
Didnt expect that aye! Haha. Looks very clean with you setup. Lovely leftovers once you took the original spoiler off there :lol: :lol:
still building the Megasquirt up...
Tepper
Has thanked: 1 time
Post by Tepper »
Looking good Ian, how are you finding the MS build so far? If you hit any snags, give me a shout - I think my build is likely very similar to yours so I may well have come across some of the same issues. g-l
thanks Will, I might need your advice to set it up..... it's almost built now, just need to add the final few components and wire the daughterboard to it then it's time for the loom and programming :? :shock:
Looking good Ian s(c)
That rev counter only goes up to 8k though ;)
Has thanked: 511 times
Been thanked: 454 times
Nice work Ian, looking great :)
Tepper
Has thanked: 1 time
Post by Tepper »
ian65 wrote: Sun Jan 21, 2018 5:37 pm thanks Will, I might need your advice to set it up..... it's almost built now, just need to add the final few components and wire the daughterboard to it then it's time for the loom and programming :? :shock:
Sweet! When you add the daughterboard, solder the wires on so they exit on the same side as the components, so that it will end up sitting upside-down compared to the main board - I didn't realise this at the time but the fit will be better.
Does it have a special power supply...........some sort of step down transformer power stabiliser?
DKWW2000 wrote: Mon Jan 22, 2018 5:48 pm Does it have a special power supply...........some sort of step down transformer power stabiliser?
Glad I'm still old school Pete, carbs are enough for me ..... :D
Mmmm Megasquirt h[b[
