TWiR 1986 S3 TWR
Re: TWiR 1986 S3 TWR
Looking at that a 1/8th" drill to get a hole in the blind threaded leftover, then a stud extractor. That's what I would try first.
- Has thanked: 300 times
- Been thanked: 146 times
LOL. I had to find a conversion chart to see what 1/8th" is in new money. Turns out it's 3.175mm so a 3mm drill will do fine then. I considered using a left handed drill bit to aid the process or will a standard HSS bit suffice?codge wrote:Looking at that a 1/8th" drill to get a hole in the blind threaded leftover
- Been thanked: 10 times
Hi mate,
I'll have to cop to that
I hate those sump bolts. You've got to get them tight enough to stop the sump leaking but without damaging the piss weak bolts.
I think I'm gonna put some studs in my next motor.
Drill a hole into them like Codge said, then try stud extractors:
http://www.ebay.co.uk/itm/5-PIECE-PCE-D ... 257258d770
You can get away with the odd missing bolt in the sump though.
- Has thanked: 232 times
- Been thanked: 276 times
Dont buy those stud extractors, I've got a set of those, they're useless.... Buy or borrow a decent set
- Been thanked: 3 times
Yeah, cheap stud extractors are a false economy. They're case hardened which makes them very brittle and when (not if) they snap in the bolt, they're then impossibly hard to drill out
You may well find just the heat from drilling the bolt is enough to free it anyway. I've never used this style of extractor but they have a reputation for being more robust than the threaded type; http://www.carbuildersolutions.com/uk/s ... ractor-set
No, blame whoever barbarianised those bolts in the first place
I've owned and worked on '80s Kawasakis, there's nothing I don't know about extracting fasteners from inaccesible orifices where they've cold-welded themselves into a horrible fused lump, lol. I'd rather pay someone to spark-erode that bolt out of the hole than try to drill a snapped stud extractor out of it
Yabba dabba doo!
Spark erosion is your friend.
- Has thanked: 365 times
- Been thanked: 165 times
Repair it with helicoil, nearly the same as this set: http://www.ebay.de/itm/Gewinde-Reparatu ... 0753637475
Any HSS bit.....it's the stud extactor that puts the left hand bite into the drilled hole. The more you turn anticlock the more they tighten up and the flukes bite into the remaining screw material to unscrew it out.KiwiDave wrote:LOL. I had to find a conversion chart to see what 1/8th" is in new money. Turns out it's 3.175mm so a 3mm drill will do fine then. I considered using a left handed drill bit to aid the process or will a standard HSS bit suffice?codge wrote:Looking at that a 1/8th" drill to get a hole in the blind threaded leftover
But the extractors can break easily (they're hardened steel), so as said buy quality.
You need an extractor that's the right size for the hole/material you're extracting. A small/medium one in this case. A set will be best.
Gently tap the extractor inwards into the drilled hole to seat the flukes before unscrewing. This will help loosen the remaining bit of thread as well.
Some jobs like this one respond to gentle handiwork rather than brute force bash bash.
