Josh....You've got to be able to get under it before buying. If that's not possible, walk away.
Look at the the guides on here re rust spots first. Vital to check the rear reinforcing plates to the chassis, the rear sills, the front chassis rails.....
Thank you for the advice dude, I will ask about that when I call to see if i can jack it up and have a look underneath.codge wrote:Josh....You've got to be able to get under it before buying. If that's not possible, walk away.
old Elford Turbo photo.... no other details known
and this triple rotor beauty... I'm sure I've posted this car before
WPB182Y series 2 project.... off the road 19yrs
bid up to £2,028.28..... that's a lot of dough for a project that's been off the road for 19 yrs...... and that was reserve not metThreesevens wrote:and another one!
http://www.ebay.co.uk/itm/Mazda-RX7/162 ... 1903542638
C741CKL Elford Turbo project car
C741CKL spares or repairs plus Elford Turbo and other spares on Gumtree in Devon £1500
"85 fb with lots of spares including another engine 2 gearboxes spare rotors manifolds carbs Windows and much more. Most importantly I have an elford turbo set up as well I would like to see £1500 for everything"
https://www.gumtree.com/p/mazda/fb-rx7- ... 1164058953
- Been thanked: 188 times
http://www.rx7fb.com/viewtopic.php?f=20&t=12&start=2400
Now on EBay:-
http://www.ebay.co.uk/itm/MAZDA-RX7-FIR ... Sw2GlXF23n
						Now on EBay:-
Re: WPB182Y series 2 project.... off the road 19yrs
surprise, surprise..... it's relisted...... seems like the last genuine bid wasn't high enoughian65 wrote:bid up to £2,028.28..... that's a lot of dough for a project that's been off the road for 19 yrs...... and that was reserve not metThreesevens wrote:and another one!
 http://www.ebay.co.uk/itm/Mazda-RX7/162 ... 1565496232
ian65 wrote:surprise, surprise..... it's relisted...... seems like the last genuine bid wasn't high enoughian65 wrote:bid up to £2,028.28..... that's a lot of dough for a project that's been off the road for 19 yrs...... and that was reserve not metThreesevens wrote:and another one!
I take it the consensus on this was it would require a bag of work?
Almost impossible to judge it without seeing the underside.?
these cars nearly always rust from the ground up and inside out and hide their rust really well...... by the time the outside starts to look scabby you can bet that the shell is very corroded. This also means that even tidy looking cars need checking very carefully and also why resprayed cars need a photographic record to show their pre-respray condition and the work carried out..... cars needing minimum panel prep can be resprayed to look really tidy and a bit of underseal can hide underbody rust but beneath the shiny paint and underseal the rust is still there waiting to break through again.
This white car may well be clean and solid but who knows without getting underneath it and checking all the usual rust points..... have you checked out the forums guide to body corrosion?
http://www.rx7fb.com/viewtopic.php?f=26&t=36
IMO this car is worth a grand tops.... less maybe depending on how much work it needs.
