Page 3 of 4
Re: Twin SU Carbs - Hif 44 1 3/4"
Posted: Sat Oct 07, 2017 8:53 pm
by DKWW2000
ian65 wrote:I thought S3 inlets blanked off the EGR port
Good idea to fit stainless core plugs into the water channels, a touch of RTV then new O rings with the new gasket.
I made my own gasket which covers them up, as the Inlet is solid. I can always re-instate easily then.
Posted: Sat Oct 07, 2017 9:16 pm
by DKWW2000
Connected up today, She started 2nd turn (sounds throaty)
Strange thing, after she warmed up I decided to tidy everything up, fuel lines etc She would only start/run when the return fuel line was made with braided pipes
If I used any other pipe it would not even fire? Took a while to work this out.
These are the run off/float chamber return lines which only flow when the float gets stuck, this was not happening but there must be a logical reason. On a Austin Maxi I had if the float got stuck it overflowed onto the exhaust manifold
Pictures will follow soon. Test drive on Monday
I am after a set of OMP lines if any are For sale?
Posted: Sun Oct 08, 2017 6:21 am
by spirit r
Posted: Sun Oct 08, 2017 8:43 am
by DKWW2000
Thanks Thomas, At the moment I have kept the existing stock pump, from what I have read it should be OK.
Posted: Sun Oct 08, 2017 7:13 pm
by DKWW2000
Sorted out the pipework a bit more today & changed the OMP for a new one. The new one "Ticks", if you touch it you can feel it ticking as well? is this normal as I have never noticed it before
Confirmed the brakes were OK & took her for a spin
She growls when you put your foot to the floor, which quickly turns into a snarl at about 5000rpm.
It is certainly a lot quicker & louder, power is there from the start & feels like a lot more torque. Does not feel lumpy on deceleration below 2000 rpm.
Not sure I like the look of the engine bay
I miss the blue Air Filter & it seems to have lost its charm (I do like the performance though).
I will now set about cleaning up the old manifold & carb & see how I get on with the change.
Posted: Sun Oct 08, 2017 9:23 pm
by myatt1972
Lovely job there Pete, I like the look of the engine bay.
I said the same as you about seeing how I would get on with a change of carbs and they're still on
Posted: Tue Oct 10, 2017 12:05 pm
by DKWW2000
Can I now put TC after the MAZDA badge
Posted: Wed Oct 11, 2017 11:59 am
by Hobbawobba
That is very cool! I quite like the look of them aye
Posted: Wed Oct 11, 2017 4:52 pm
by DKWW2000
Hobbawobba wrote:That is very cool! I quite like the look of them aye
Thanks Jess, I am now going to try & reduce the excess wiring loom so I am going to try And make another that will plug in & just supply that which remains.
Posted: Wed Oct 11, 2017 6:45 pm
DKWW2000 wrote:Hobbawobba wrote:That is very cool! I quite like the look of them aye
if you can get a spare engine loom to dissect it's easy.... these are the connections at the plug on the inner wing... water temp 2 is the water temp sensor on the back of the water pump housing which controls the choke magnet.
