Re: Carb spacer
Posted: Sun Dec 21, 2014 8:34 pm
She's alive!!!! But it wasnt easy though see fort me every step of the way carb build was perfect if i do say so myself ! However i think i had some sticky seals as its been a year since ive fired her up but some atf and two stroke in the bores and a bucket load of smoke and she runs idles at 1100 till warm then drops to about 850 -900 rpm im happy at that needs more tinkering as to achive this the mixture screw is at 5 turns and the air at about 1-1/2 so im dragging in air some were but it is progress doesnt like the light being on and start to loose rpm on idle but the battery is no were near new ! Also the first time its ever hit temp on gauge so hopfully its freed of the seals a bit needs a good revving but the exhaust has now fractured and sounds like a jet thanks to every one for your help so far .fez
