Are you saying that coolant is coming from the expansion bottle under pressure? And if so, how full was the expansion bottle when cold?
If you start out with the expansion bottle level at MAX, then the coolant has little room to expand and will quickly accommodate your engine bay. Also, the halfway reference will tell you if you are using/losing coolant as well. The level drops and the coolant is sucked back into the system as it cools.
