Once I had seam welded just about everywhere, it was time for some fabrication.
First up, some reinforcing plates for the harness fixing points. these have to be 75cm2 both sides of the floor.
I also need to cut out a section of the transmission tunnel to be able to fit the drivers seat, otherwise the seat would be too high for me to fit !
Floor cut out:
Reinforcing plates need to be fitted for the seat mounting points
All done :
And it all fits ! Just need to lower the seat for more clearance.
Next up a tray to fit the battery:
I bought the fitting bracket to allow me to make the the tray, of course checking that the battery will be man enough for the job !
Making the plate:
And fitted in position, low down as possible.
Next, some brackets to take the bonnet pins for the rear hatch:
