first rotary experience
ruby
Re: first rotary experience
Post by ruby »
Not bad at all :D too bad my rear wheels are 195/60 instead of 185 :lol:
But thx anyway :D
´´speed has never killed anyone, suddenly coming to a stop that´s what´s get you ´´
Rogier
Post by Rogier »
ruby wrote:Not bad at all :D too bad my rear wheels are 195/60 instead of 185 :lol:
But thx anyway :D
That's actually even closer to the original. ;)
FB just for oldskool driving fun
FC TII vert (modified) just to annoy FD's
Hi Ruben,
a warm welcome to the forum, nice car, have you fitted the Elford turbo kit yet?
There's loads of good info and advice on here (apart from rolling diameters!).
cheers,
Ian
0-0 0-0
ruby
Post by ruby »
hi ian
thanks for the welcome and i´m just fitted the elford turbo today but i´m still waiting for an oil cooler and the oil lines so can´t start it up yet :cry:
I already looked at the turbo section of the forum and indeed very good info to be found :D
I wanted to post some pictures how the car looks now and the progres but i don´t know if i can show them in this topic or if i should open a project topic :oops:
it's probably best to open a project thread in 'RX7 Rides and projects' then everyone can follow your progress. Did you get the solenoid and wiring to retard the ignition?
ruby
Post by ruby »
ok i´ll start up a project thread :)
and yes i did get the solenoids and black box with it to retard ignition but i didn´figured it out yet how it works or is supossed to be connected but i did saw something in the turbo section about it :D and i also don´t know where the oil lines of the metering pump go since the su carb doesn´t have any connections for it :?
here's a diagram I put together a while ago showing the carb connections and where the omp lines connect to it.
https://docs.google.com/open?id=0B8jAGJ ... QzZGQ2ZTJk
Elfords did 3 different versions of the black box... let me know which one you have and maybe I know the connections
ruby
Post by ruby »
Thanks the diagram explains it all :D
And i'll take a picture of the black box so you can see what type it is
But thx anyway :D
Ruben
If you want to keep the 14 inch wheels, you can fit 185/65/14. This is less than 1% difference from the original 205/60/14 so will have minimal effect on your speedometer readings. And it's a much more common size to find.
And..... welcome to the forum too.
ruby
Post by ruby »
thanks for the welcome dave and as far as the wheels go i think i´m gonna stick with what i have or switch to original :D
