Page 20 of 34
				Re: 84GSLSE 13BREW Swap build
				Posted: Tue May 14, 2019 6:24 pm
				by DWNUNDR
				Might actually work out..
Before and after por15
- 19D256CC-7017-451C-858E-7248B00781C2.jpeg (251.24 KiB) Viewed 16639 times
				Posted: Tue May 14, 2019 10:38 pm
				Wow, that's come up really well
				Posted: Thu May 16, 2019 6:09 pm
				by DWNUNDR
				I spoke to early.. it failed.. sections started peeling and now I dont feel confident or want to risk running it..
So I am going to try again with the better tank thats is in the car currently.. but I will try electrolysis first, then go thru the por15kit.. I watched Aaroncakes video and after I realized it failed cause I rushed it...
				Posted: Sat May 18, 2019 6:49 pm
				by Hobbawobba
				Ahh yeah. POR15 is very specific about how it needs to be done for it to work properly aye. Fingers crossed this next attempt works out
				Posted: Mon May 20, 2019 6:13 pm
				by DWNUNDR
				Posted: Mon May 20, 2019 6:16 pm
				by DWNUNDR
- FDD71779-15AA-4081-B7D1-4F151F649A9F.jpeg (263.37 KiB) Viewed 16788 times
Also the tank I had in the car was mint so I may not even seal it
				Posted: Mon May 20, 2019 9:26 pm
				by spirit r
				DWNUNDR wrote: ↑Mon May 20, 2019 6:13 pm
Tank attempt 2.. changed the pot design... I made a test box to test the magnifier in 6jpeg8E48693B-1F06-452B-9608-CFB40C8669D4.jpegDAF4C722-3D4B-4829-972A-D24241706203.jpeg
Should be good having a drain plug, getting out the mud was building in that sump!
				Posted: Fri May 24, 2019 6:01 pm
				by DWNUNDR
				Motor is back in
Gas tank is in
- 4BAD583D-12DD-4536-A020-DEBA1A4366EF.jpeg (366.75 KiB) Viewed 16754 times
- 525472DD-2238-4074-AC3B-6F6EAA7A1EFA.jpeg (271.4 KiB) Viewed 16754 times
- 65B00605-A763-4ED8-A3A5-866ECDEFAEFC.jpeg (287.5 KiB) Viewed 16754 times
				Posted: Wed May 29, 2019 6:24 pm
				by DWNUNDR
				trying to get done for my first car show on June 14th... currently working on the exhaust manifold modifications - cut the existing wastegate pipes off and am repositioning them in a more direct flow with the exhaust ports to try to eliminate some boost creep we were getting on the last motor..
PIA.. hahaha
Water-Meth setup should arrive today so then I have to install that as well...
				Posted: Thu May 30, 2019 6:17 pm
				by DWNUNDR
