So putting everything back together and found out the metal fuel pipe going into the fuel rail has a tiny leak, must have been bent.
Tried patching it with some fuel hose slid over the top, but it's not working.
So, what is this part called and where can I get one or a similar circular connector to attach a hose to?
Edit: banjo, that's the bloody name.
So I used a hose clamp instead of the cable ties as they just didn't have enough force and it seems to be holding for now. Will get some hose and a replace banjo bolt ordered and fix it proper. Just want to start it and check for exhaust leaks.
