Poly Bush tips
Re: Poly Bush tips
You'll do for me Dave .... I bought these poly bushes 5 or 6 years ago ... I get there in the end .... stay safe
Re: Poly Bush tips
I forget where I've put things after five or six days, let alone years! (If it's my glasses, it can be a matter of minutes). :roll:
I got lucky with finding the ball joints which I'd purchased circa 2012. I was searching for something else a few days previously and had come across them in the process.
I've lost count of the times I've ordered some part again because I've forgotten what box or crate it is hiding inside! :oops:
Re: Poly Bush tips
[/quote]
I need to replace my clutch slave and I know I've got at least 2 of those somewhere,
Tried to fit the bushes into the Watts link rods today, the lube they supply with them is as sticky as hell and goes everywhere.
Has thanked: 44 times
Re: Poly Bush tips
A7RXY wrote: Fri Feb 26, 2021 4:01 pm I've lost count of the times I've ordered some part again because I've forgotten what box or crate it is hiding inside! :oops:
[/quote]
Dave i am sure I ordered one for you about 5 years when I got a bulk order from RockAuto
Re: Poly Bush tips
You did Kevin that and a master, they are all stored in by garage, but until I get my axle fitted and move the car I can't get to them ....
Re: Poly Bush tips
[img][http://imgur.com/a/nyCcuOl/img]
Just trial fitted the sway bar links .... looking good
Re: Poly Bush tips
Nice touch with the red mounting brackets th:
Re: Poly Bush tips
Slowly getting there
[http://imgur.com/a/FfsJp8T]
Re: Poly Bush tips
KiwiDave wrote: Sat Feb 27, 2021 6:53 pm Nice touch with the red mounting brackets th:
KiwiDave wrote: Mon May 18, 2020 8:16 pm Will you still respect me in the morning Thomas?
I was actually going to rattle can the thing but I surcumbed to the 'who is going to be looking under your car?' argument, which at the time was quite a reasonable question. 😁
I can see you have changed your mind Dave. The german say: "Außen hui innen pfui"
Re: Poly Bush tips
