1990 RX7 FC TII Vert
Re: 1990 RX7 FC TII Vert
you'll look rather splendid old chap on your way to RetroRides after an early morning scramble.
- Been thanked: 187 times
No ....NCO ic Choc's AwayKiwiDave wrote:I'm guessing that your rank would have to be Flight Commander then?
Flight Commander = FCDKWW2000 wrote:No ....NCO ic Choc's AwayKiwiDave wrote:I'm guessing that your rank would have to be Flight Commander then?
- Casey
- Has thanked: 505 times
- Been thanked: 450 times
Looking good Pete
Been having issues with the Car, rough idle, bogging out, missing, rough acceleration/slowing down!
Checked/replaced HT leads, Plugs. Filters......etc etc.
Cleaned electrical connections & checked BOV, IACV, BAC, Ash Tray, Washer Bottle..........etc etc.
Multimeter on TPS seemed some unusual readings/gaps in resistance (was futile), so I adjusted it (manual said not to) & found it moved the "Dead" spot further up the Rev range ............Yippee I think I found the problem, not a great deal of info on the Forums about it, so I ordered a new one ($$$$$$) from AUS.
2 weeks to arrive so just fitted (have to remove Intercooler/Alternator & various wiring connectors.......................YIPPEEEEE
All sorted & Idling & accelerating smoothly now.
This is the offending electronic TPS gizmo bastard!
Like all the best troubleshooters, if it says 'Do not Adjust' or 'Not Adjustable' , mess with it anyway just to be sure LOL. Well done that man.DKWW2000 wrote:..... so I adjusted it (manual said not to) & found it moved the "Dead" spot further up the Rev range ............Yippee I think I found the problem,
