Hmm, I'll have to keep an eye on my temps when I get back on the road. Maybe make some ducting or relocate it
I assume you're getting decent airflow?
Oil temp sensor
- Has thanked: 627 times
- Been thanked: 218 times
- MelloYello
- Has thanked: 22 times
- Been thanked: 52 times
Re: Oil temp sensor
The high oil temperature readings i am getting are around 100C degrees and above.
Last night I remove the thermostat located in the cooler which blocks the bypass when up to 65C degrees. I then blocked it with a bolt washer and lock nut.
Big improvement. The oil temperature increase from cold is now much more gradual and seems to be holding around 90C when I am moving and have good air flow.
I still plan to do a trial swap with a cooler that has a proven history, as I believe the cooler may have blockages. Especially if it has not had good flow all this time.
- kenwhiteside
- Has thanked: 2 times
- Been thanked: 21 times
Re: Oil temp sensor
90-100degs is perfect for oil temp. I would not want it any cooler! Jacking the stat in the oil cooler is making warm up slower, this is not really a good thing...
Remember with the beehive cooler your oil temp will be pegged to coolant temperature at a minimum, this is pretty standard in most vehicles these days. Unless you are operating above 130deg I would not worry, this is really only an issue as you will see a drop in oil pressure. Oil temp limit is probably 140ish.
Re: Oil temp sensor
Racing Beat say that oil temperature entering the engine should never be allowed to exceed 205°F. (95°C.)
Obviously, once the oil enters the motor, it will absorb heat then circulate back thru the oil cooler then thru the filter.
So, if your oil temp sensor is on a plate under the filter and you are still seeing temps in excess of the above, the cooler is not doing the job properly.
- KYPREO
- Has thanked: 14 times
- Been thanked: 39 times
Re: Oil temp sensor
To me this perfectly describes why Mazda toyed with a water-oil cooler for 2 years only (but notably not on its 13B GSLSE and 12A turbo models) and promptly threw it in the bin and never used it again.kenwhiteside wrote:90-100degs is perfect for oil temp. I would not want it any cooler! Jacking the stat in the oil cooler is making warm up slower, this is not really a good thing...
These water oil coolers ran on the edge for street driven 115hp engines. Anything more demanding and you're pushing 100C, which will kill a rotary engine. The reference to most modern vehicles isn't applicable as, unlike piston engines, rotary engines use oil for cooling.
I would defer to the Racing Beat advice KiwiDave posted
http://www.AusRotary.com
Re: Oil temp sensor
Have you considered an oil cooler fan? https://www.thinkauto.com/acatalog/On_l ... ts_16.htmlMelloYello wrote:The high oil temperature readings i am getting are around 100C degrees and above.
