Engine Oil
Re: Engine Oil
MelloYello wrote:it is oil - just chuck it in
s(c)
Re: Engine Oil
10W40 or 15W40 that meets A3/B4 spec. Cheap and change it often.
PS semi synth is mineral oil with a dash of synth in it.
PPS put the old stuff in the fuel tank for premix.
Re: Engine Oil
OK, I'll use 10W40 then. I will stick to Castrol power 1 2 stroke for premix though haha.
Re: Engine Oil
TOOL wrote: Cheap and change it often.
The best i ever read about rotary oil. BTW i always change oil filter and drain the air cooled oilcooler too. Rotary oil must cool the engine from the inside and my 12A experience is mineral oil transporting heat better. Change interval is shorter then synthetic oil interval.
Rotary 1
Re: Engine Oil
Post by Rotary 1 »
MelloYello wrote: Mon Apr 24, 2017 9:13 pm it is oil - just chuck it in
I’ve heard using synthetic wasn’t good in a Rotary. True or false? I’ve always used Pennzoil 10w30 & 5w30 that’s what the shop used & told me to use after they installed a new 13B. I’ve also never mixed with my gas either. It’s been 10-15 years since the work was done & 5 - 10,miles a year at the most. Is using this oil bad?? I live in AZ
Re: Engine Oil
Cldblded Rotary 1 wrote: Tue Feb 19, 2019 4:20 am
I would only use straight mineral oil as the original spec. The Pennzoil sounds right.
Premix is worth thinking about as an original engine could have an inbuilt oil metering pump that's now approaching 40 years old.
Re: Engine Oil
GTX is still a mineral oil base, just with a small amount of synthetic blended in to help with viscosity and temperature control.
Many of us have used GTX for decades and decades. And you can still find it on Ebay.
Rotary 1
Re: Engine Oil
Post by Rotary 1 »
codge wrote: Tue Feb 19, 2019 11:11 am
Since this is new to me i take it the metering pump is internal? I remember seeing on my invoice that was replaced or rebuilt. I’ll have to look now at my invoice. If not should I be premixing?
Re: Engine Oil
The oil pump is on the front corner of the engine, external, that's on the 12A. Presume 13B is the same.
I just think premixing is belt & braces. I haven't noticed any excess smoke from it.
Re: Engine Oil
thought I would add that since I created this thread I have done some more research and I use fully synthetic in my 13B engine which has OMP removed. I used total Racing quartz 10w50. I also use it in my 12A with omp still intact, many people say modern synthetic is no problem in rotary engines.
