New Wheels - Temptation
- Been thanked: 187 times
Re: New Wheels - Temptation
Doh! They protrude more than I thought.
Thanks for taking trouble to educate me. What Width are stock wheels & what width/ET do you think I should have only wanting them to stay inside existing arches comfortably with F195/R205 x 65 x 15 tyres?
- Has thanked: 627 times
- Been thanked: 218 times
These are some wheels I have l that I test fitted.. 14x7 offset believed to be between 0 to +10. I haven't measured though so can't say for sure! Just incase it helps at all
- MelloYello
- Has thanked: 22 times
- Been thanked: 52 times
Hobba wobba ^^^^^^^ if they are 7s then I would say offset is closer to 20 to be that flush.
Lol, you don't want to run a 205/65R15. Its not a 4x4.
Should I just go for the same width as my stock wheels (Whatever they are) with a offset of ET 25 or 30.TOOL wrote:Lol, you don't want to run a 205/65R15. Its not a 4x4.
What size tyres do suggest, I do not like low profiles (rim damage/punctures) remember I live in the stick of Devon so M&S/AT tyres are sensible down be yerr! If there is grass in the middle of the road, it does not mean your on a Dual Carriageway
A 195/50R15 is the same as a 185/60R14 is the same as a 175/70R13 is the same as a 155(80)R13.
195/50R15 are cheap and plentiful. Not teeth rattlers either.
I reckon if you're paying for wheels, you have to go wider. Stock would be 14x6 I expect.
You want 6.5J to 7.5.J.
5.5 is rubbish. That's like a 70s steel rim.
You are not wrong. Who specifies a 205/60 on a 5.5 rim. That's the tire version of a muffin topTOOL wrote:5.5 is rubbish. That's like a 70s steel rim.
