fed up trying to get her to run properly, 12a elford
rip7
Re: fed up trying to get her to run properly, 12a elford
Post by rip7 »
got my self a smoke machine of ebay [ halloween syle] so i will smoke it up this weekend to see if it is the dreaded vac leak. if it is then its turbo off. [was easy out the car] if not i will give kev's carb man a bell {the carb had no isues before the engine rebuild ? ] summers cumin so i will get my finger out, and not buy any more projects that take my time away from my long term love affair with my elford, owned her 18 years nearly. hope all is well with your car kev ? and ian thanks for the imput
rip7
Post by rip7 »
yes its the dreaded vac leak. started to take off the inlet manifold, looks like the exhaust manifold will have to come off. to get to all the bolts, [ 2 have studs and nuts in a recess,so you cant put a socket on them ] did not torque these two up last time. think i need a special nut about 25mm long to clear the recess to get a socket on [ proberly the problem] now need a exhaust manifold gasket, any idea of part number?
this is the exhaust manifold gasket that you need.....
http://www.rockauto.com/en/catalog/mazd ... asket,5400
http://www.rockauto.com/en/moreinfo.php ... 50&jsn=442
other styles of gasket won't block off the emissions ports and you'll get a blow.
dirt cheap from RockAuto but postage knocks it up... still cheaper than buying one in the UK though, especially if you can team up with someone else on here who wants something and split the shipping
rip7
Post by rip7 »
thanks for that lord elford, gives me a good excuse to order some other goodies as well
rip7 wrote: Lord Elford
W(p W(p W(p W(p W(p W(p W(p
rip7
Post by rip7 »
got the exhaust manifold and inlet manifold off today WHAT A PIG OF A JOB . exhaust manifold gasket looks ok , might re use it? . inlet manifold has a small cavity [ indent] in it, should i fill it [ plastic pading ]? also should i do away with the o rings and fit plugs. dont ever want to take that lot off again EVER,
it's a real sod of a job :D :D
You can reuse the exhaust the exhaust gasket... clean it thoroughly with brake cleaner then put a very thin smear of exhaust paste on each side before bolting it back up..... use some proper stuff that comes in a cartridge to go into a mastic gun, not that crap Holts GunGum rubbish that turns to dust and falls out. A proper motor factors should have the proper stuff.
You can fill any imperfections in the manifold mating surface with Araldite or JB Weld and sand it down. Use a genuine Mazda inlet gasket... they're only about a tenner from a Mazda dealer.
Definitely lose the O rings and bang a couple of 20mm stainless coreplugs in...
you can see the parts I used to put mine back together here...
http://www.rx7fb.com/viewtopic.php?f=4&t=2174&start=150
although the last time I pulled my turbo off I reused the manifold gasket and put exhaust paste on it.
rip7
Post by rip7 »
got my inlet manifold gasket, tried the inlet manifold back on but it dont cover the open block port under the tall ports on the centre iron [ vac leak ?] am i missing something? lord elford words of wisdom.
Photos please
rip7
Post by rip7 »
the elford inlet manifold does not fully cover the EGR port, should it be blanked of ? [ tried to post pictures] have i lost something ?
