Cold engine leans out till it stalls
Th0m4s
Re: Cold engine leans out till it stalls
Post by Th0m4s »
May I introduce to you: My problem! :|
Sorry it was late allready and too dark but I found out a bit more. I adjusted the choke flap according to the manual but the engine still was stalling after about 30 seconds. I started it again and when the rpms started going down I closed the flap a bit by hand. The engine was immediately running better then. So as I see it the choke can (don't know how I should call it. The black round thing which pulls the choke open by a bimetallic spring when it gets hot) pulls the choke flap open too fast.
I'm going to try and adjust it a bit tomorrow. unfortunately I only have one try per evening because the engine has to be cold. I'm a bit worried I won't be able to adjust it enough because at one point it won't be able to pull the flap open enough for the normal running hot engine. :?
Rotary Engines: Behold the power of two doritos on a stick!
TOOL wrote:You want to close the choke more. Too much air, not enough fuel. That's why it leans out.
Exactly
Th0m4s
Post by Th0m4s »
I finished adjusting the choke today. You were right, TOOL. I managed to adjust everything so the flap will stay closed for a longer time and now the car starts without any problems. So thanks for helping. th:
Chur
