Carb spacer
Re: Carb spacer
Maybe it's just bottom then. Sorry, I'm going from memory.
http://www.ebay.com/itm/Mazda-Rx7-Rx-7- ... cc&vxp=mtr
I don't have any vaccuum nipples except for vac advance and reused the old ones when I've worked on other peoples carbs for them. What was in your kit? I've got 3 different kits here.
Have you got a pic of the underside of the thottle body on the carb?
Re: Carb spacer
Fez, have you downloaded a copy of the parts catalogue out of the library section of the forum...essential reading and reference if you're working on your car...they'll show how all the parts go together
Festa662
Re: Carb spacer
Post by Festa662 »
Will do it tonight ian maybe should have done that first! Ha ha fez!
Fb gen 3 partially restored
Re: Carb spacer
I don't think they're detailed enough
Festa662
Re: Carb spacer
Post by Festa662 »
So heres my carb base and the spacer that was donated to me by myatt
Spacer
Spacer
Carb base
Carb base
Re: Carb spacer
Have a read of this...
http://www.rx7club.com/1st-generation-s ... ey-799265/
The gaskets in the rebuild kit aren't direct replacements for the factory bonded ones on the spacer plate so forget about them, the factory ones aren't available to buy separately, only on a new spacer.
Just very slightly rough up the surface of the bonded gaskets, apply the finest film of blue hymolar and bolt it all back up.
Festa662
Re: Carb spacer
Post by Festa662 »
Intresting read that ian ! But why would they provide gaskets just to confuse us gonna install back on the car this weekend and see how it goes need to set the mixture and idle hope for the best how do you guys set the mixture for emmissions? I.e mot ?
Re: Carb spacer
Festa662 wrote:Intresting read that ian ! But why would they provide gaskets just to confuse us gonna install back on the car this weekend and see how it goes need to set the mixture and idle hope for the best how do you guys set the mixture for emmissions? I.e mot ?
These cars don't get tested for emissions....just a visual check for smoke so don't worry about emissions,just get it running
Re: Carb spacer
I don't remember using gaskets when I re-assembled my carb setup :? I thought the spacer plate was the gasket?
Re: Carb spacer
Lucky wrote:I don't remember using gaskets when I re-assembled my carb setup :? I thought the spacer plate was the gasket?
me too... ive lost count of the number of times ive taken these off and refitted them and ive never used a new gaskets and never had a problem
Return to “Wanted”
