Page 2 of 3
Re: Fuel tank refurb questions
Posted: Thu May 15, 2014 11:01 pm
it wasn't just the roof Derek, the inner A posts had gone, so had the screen pillars, the front scuttle and the inner bulkhead under the wiper tray..... it was just too far gone.
Posted: Fri May 16, 2014 7:20 am
by mpk490p
Lucky wrote:This is what I figured, but I'm confused by the little black plastic clip thing... there doesn't seem to be anything for it to clip to
It clearly only fits on the one line in the tank because the other is too small a diameter, but it's hardly what I'd say a tight fit. Is it really as simple as when it's in place there isn't enough clearance between the bottom of the filter and the base of the tank that there isn't space for it to fall off? Seems weird
I found this on Ian's silver car build thread
but I dunno if that helps. Is that really how it fits?
By the way, is this the same car that the windscreen surround has rotted through, Ian? It almost moved me to tears going through that thread thinking how cruel it's turned out
The hole in the clip is for weight saving
Posted: Fri May 16, 2014 1:56 pm
by Lucky
lol ^^
weird filter thing is weird
Posted: Fri May 16, 2014 4:42 pm
by MelloYello
Lucky, did you not have a friend that was fabricating alloy tanks?
Posted: Fri May 16, 2014 4:54 pm
by Lucky
Yeah, that was the plan
As is often the way it became one of those things where the time and perhaps more importantly the errrrm... missappropriation of work equipment and stuff meant it wasn't going to happen. Shame really, cos the one he made up for his missus' car was a work of art
Posted: Mon May 19, 2014 5:17 pm
by Magnus
Lucky wrote:Ok, so I got a spare tank off Damon and thought since it was off the car I might as well make sure it's future-proof enough to outlast the rest of the car. The outside is all POR15 painted, which I might just go over, but I thought I might seal the inside with that POR15 tank sealant stuff too. Anyone had any experience of using this? I'm guessing Ian has, lol.
Plus, the filler hose could maybe do with replacing. Certainly the little overflow/breather pipe has cracked, though this is easy to replace as it's just flexi 15mm fuel hose. The filler neck hose is the problem; it's 48mm diameter and proper fuel necks with bends only seem to come in 45, 51 or 57mm diameter
You can get Samco silicone "fuel" hose in 48mm but it states it's only for short-term exposure to fuel, not for permanent immersion or transfer of it. The bend in the original pipe is gentle enough that you could probably get away with a straight run of silicone pipe without it kinking, but I don't want to swap in something that's going to degrade quickly. The original isn't in too bad a nick, but is it worth taking a chance on putting something back that's probably already 30-odd years old?
Finally, gaskets... is there any way of discovering parts numbers for the cork gasket on the lift/return pipe plate and the rubber gasket on the fuel sender? Is there like a Mazda parts list online anywhere?
Thanks as always in advance
The part numbers for those 2 gaskets are 8871-60-962A and FA54-42-182, at least for an 84-85. They should cost around 10 EUR each from Mazda.
Posted: Mon May 19, 2014 6:35 pm
by Lucky
That's brilliant, much obliged for that
Posted: Mon May 19, 2014 8:26 pm
by DB RX63
Lucky,
I managed to pull this out this weekend, hope the pics are of use ?
Cheers
DB
Posted: Mon May 19, 2014 9:38 pm
by Lucky
Yeah, kinda, thanks. It confirms how I ended up with mine being, although to be fair there's no other way it can really go! Still looks like there's something missing there, though, that clip bit looks like it ought to... well, clip to something really
Are cable ties petrol-proof?
Anyway, I've ordered in a POR15 tank inside sealant kit so I'll report back on how that all goes when it arrives and I man up enough to try it. This tank's in really good nick, but knowing how rare they already are and how badly they can rot I'd like to do everything possible to future-proof it
Posted: Mon May 19, 2014 9:46 pm
by RamoNZ
Maybe the clip thing is something to do with the fuel injected 13b?
Derek - could you measure the width and length of the top section that has the hose connections? I wonder how close in diameter it is to the FC fuel injection top and if that would be an easy way to drop a high pressure pump in.
Height and width at longest points for the pipes and filter would be interesting too if you get a second.
