Have you checked under your windscreen trims?
Re: Have you checked under your windscreen trims?
Another horror story! Take heed.
Christ, and I thought I was having a bad week! I can only imagine how gutting that is after two years of work, and knowing how particular you are about getting everything perfect, Ian, I guess that was two years of hard work too. :cry: Horrible to see :shock:
myatt1972 wrote:BLOODY HELL :shock:
X 2 for that comment..... :o
Lucky wrote:Christ, and I thought I was having a bad week! I can only imagine how gutting that is after two years of work, and knowing how particular you are about getting everything perfect, Ian, I guess that was two years of hard work too. :cry: Horrible to see :shock:
yeah, it's a bit demoralising but after the year I had last year, car problems are easy to deal with..... I'll just put it behind me and move on.
biznatch
Post by biznatch »
I'm too scared to check mine now after seeing those photos Ian. Sorry to hear about this, it must be heartbreaking after putting in so much planning and effort. :(
Jeez today has been some depressing reading on the forum aye! Such a shame to see this happening, Ian! :cry:
Been thanked: 111 times
Post by Chud »
And there was me thinking I'd seen it all. :shock:
A7RXY wrote:Before you all go out there and pull off your trims these holding clips are no longer available in the UK and on back order at Black Dragon in the US, I've tried to get some from Aus but these are turning out to be expensive. so you need to get a set before you start to investigate.
Good luck
See here for possible redemption viewtopic.php?f=14&t=2014
m swann
Post by m swann »
That's horrendous. I have never seen anything nearly as bad as that.
When in doubt....hit the gas.
Has thanked: 5 times
Been thanked: 23 times
Post by DB RX63 »
Ian,
That's tragic mate.
We all know how much work you put into the car.
DB
Return to “RX7 Exterior”
