FB S1/2 or FC oil cooler
Re: FB S1/2 or FC oil cooler
just out of interest, does anyone know if that GSL-SE cooler I posted up is the same as a series 2 cooler?...... I presume they fitted it to the GSL as well Stateside as they didn't have the beehive did they?
84/85 12a was beehive but radiators are the same.
Narrows it down whisky not quite answering the question
If GSL-SE is a full face rad like the S3 then the oil cooler will be different to a S1/S2 oil cooler. It will be like a 12AT oil cooler.
You can use it but you have to mount it in front of the rad I suspect to prevent fouling on the chassis rails and make up longer hoses to suit.
Pm sent Marc but is your inbox full?
the cooler from the usa will be with me soon...but I might not use it yet, waiting to hear back on something else...
biznatch
Did you end up fitting the oil cooler in the end? About to fit an FC cooler myself in the next couple of weeks. Did you need to get hold of a non-beehive oil filter pedestal?
You will need to change it, bud.
biznatch
Thought so, thanks for confirming mate. Wouldn't have a spare tucked away would you?
I've got a bunch. Wanna pick one up at Watford Saturday?
