Page 2 of 2
Re: J-Spec R5 12A
Posted: Mon Aug 05, 2013 9:15 pm
l-arsouille wrote:Nice th:
I know there is is different 13B housings but didn't knew there was different 12A housings ! What car is it coming from ?
As I'm writting this message I can remember I saw (only in picture) a 12A housing with 3 holes for the exhaust port instead of 1! I don't know if i t was a prototype or an earlier version of the 12A ? :|
Now you're in my territory bro. 3 hole exhauts ports is classic twin dizzy stuff (71-73). I was tripping over some today :D
Like this:
Re: J-Spec R5 12A
Posted: Mon Aug 05, 2013 10:53 pm
by RamoNZ
TD RX2s supposedly made 130hp with those tiny holes, I wonder how the timing compares to the R5 stuff?
The Euro spec Series1 engine I have has the R5 plates but much smaller exhaust ports and I believe were quoted to be 110bhp from the factory?
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 12:20 am
The thermal reactor choked the power out of the FBs. The early engines escaped this fate.
The 3 hole exhaust ports were designed to minimise noise from the engines too btw.
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 12:29 am
by Lucky
What do the "R5" and "NO" designations mean/derive from? Or are they just random Mazda codes? What cars came with these engines?
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 8:19 am
If in doubt, consult the oracle:
http://ausrotary.com/viewtopic.php?f=4& ... +irons+12a
bumpstart wrote:well, there is lots of changes between years and between markets,, in oz we dont see repus , or california spec stuff and so our info may not tee up correctly with american years and options
there is also differening and sometimes bastard combinations of inlet manifolds, some reversed, some cross ported primary to secondary , others as 4 individual runners and some with an anti buck butterfly below the throttle on only one primary
i will try and sum things up as best as i can recall of top of my head
i see early rx4 type housings, a little latter maybe than 74/75,,for several reasons
- cause i expect the 74-75 13b rotors to have 1757 stamped between rotor tip and bath
i expect if original,, the apex seals came with a long wedge piece ( longer than 76 upwards ) and a shorter main part of apex seal ,, and solid corner seals
i expect the early rx4 engine also to have a temp switch on top of the engine middle plate ( where some later engines have a vertical ACV /EGR passage )
expect quite a bit of change in markets and years in emissions spec 74-78 , and later some engines in some markets will get vertical ACV,, and others have it horizontally ( ACV on back of inlet manifold )
as far as the plates/ engines i have pulled down,, early 13bs use a letter to start the engine number,, and plates that went to 12a's will have a larger numeral
plates however readily interchange from early 13b to early 12a and vice versa
of the rx4 type 13bs ( with early and late fonts ) , i have seen end ( 2ndary* ) plates plates usually coded R5 or X or 3B
(* 2ndary here might be a missnomer,, there is a US market cosmo/rx5 manifold with reversed carb that uses the 2ndarys are the primary ports so to speak --- for the longer effective inlet runner ,, and that may just explain the unusual plate/ port combinations on some engines )
R5 2ndary port is 42 mm tall ( caliper top to bottom inside the port ) ,, and the R5 end plate feature all the through bolt holes and castings for the chain tensioner,, indications of earlier evolution
( later R5's are built with the short chain and no tensioner fitted , but still have castings )
X 2ndary port is 48 mm tall , is delete one through bolt on the rear,, and delete the chain tensioner positions , indications of a later evolution,, but curiously lacks the wedge over the oil filter dowel
3B i cant comment on as i currently dont have one to directly measure and compare, but i do recall at this point the rx4 engine ran all 4 ports the same size and thus this one should have the chain tensioner,, all the through bolts ,, is either 42 or 48mm in port height,, with centre plate to match ,, with small runners
middle plate wise,, we have several combinations again ,, some with overhead EGR /ACV, some with it below the primary runners in the horrizontal position,, and some with a water temp swtich on top instead
some of these have small ports,, some of these have large ports but small runners, and some have medium ports but large runners !!
of these ,, the most common early one is the R5,, slightly later is the R ,, and we can assume also there is an X and a 3B
( both that i havent seen yet, but i do know X exists )
there is also an N,, and an NO,, and a Y and a K that came in later 12a's ( and maybe 13bs )
again,, as IIRC --
the R5 and R middle plate port is 42 mm tall and has the tall runner AND the EGR horizontal port
the 3B middle plate must be the small runner in either 42 or potentially 48 mm with the overhead colant sensor and horizontal ACV
the X i dont know for sure , but believe its in US repus motors as middle plate
the NO is the nasty later plate that comes in most things jap,, and maybe cali , with a tiny 24mm high port , small runners and overhead ACV/EGR passage restricting further improvements
the N is a large port with horizontal ACV for same years ( 12a ) but other markets
the edit M and the K ( and i think maybe L ) are used on engines intended for possible HB cosmo use ( and potentially the US GSL-SE RESI engine ) and feature a casting for a middle engine mount between the exhaust pipes that some extractors will not fit
and so are found on 13b 6 port ( 83-85 ) , 12a 6p ( 1981 -85 ) and 12aT ( 83-87 )
the K is on the 12at ,, has horizontal ACV, small port ( just smaller than NO ) and small runners
the M i suspect is the 13b 6p,, is horizontal ACV , small runners and a smaller port again than K
L ( off distant memory ) i suspect is the 12a6p , horizontal ACV , small runner and the tiniest port ever , smaller than a pinky fingernail
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 9:10 am
there's a much more user friendly load of info on NO plates and J-Spec housings here... a guy on rx7club tears one apart...
http://www.rx7club.com/1st-generation-s ... p-1018461/
you'll see this is where I grabbed some images from to illustrate the port sizes........ very interesting stuff
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 11:41 am
I just don't like that forum
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 12:06 pm
TOOL wrote:I just don't like that forum
it's an enlightening thread though if you're interested in NO centre plates and those housings, as is this one...
http://www.rx7club.com/1st-generation-s ... s-1019622/
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 12:17 pm
by l-arsouille
Thanks for all the infos and links th:
There is so many different plates, it just makes you wonder if they care at the factory : "Oh look at this plate it will fit this engine, give it to me!"
Re: J-Spec R5 12A
Posted: Tue Aug 06, 2013 12:47 pm
l-arsouille wrote:Thanks for all the infos and links th:
How's your engine build coming along?
