Page 2 of 3
				Re: new Scottish member
				Posted: Wed May 08, 2013 2:14 pm
				by Lucky
				Not sure if you'd call it a kick as such (but I'm used to a turbo car) but my S3 definitely gets a lot more lively when the secondaries come on at ~4.5, 5k rpm
				Posted: Thu May 09, 2013 9:56 am
				by richrx
				Lucky wrote:Not sure if you'd call it a kick as such (but I'm used to a turbo car) but my S3 definitely gets a lot more lively when the secondaries come on at ~4.5, 5k rpm
Thanks lucky, it does pick up ever so slightly at about that range, im not sure if im just being hyper critical! !
 Think im going to try and video the tacho and compare it to any other videos I can find...
The car car can pop and bang so theres no shortage of fuel!
				Posted: Sat May 11, 2013 9:13 pm
				by RamoNZ
				The secondaries are vacuum operated so it should rev smoothly, but the opening will be perceptible if you are looking out for it.
If the secondaries are sticky, that would delay the opening and highten the feeling of the kick, same goes for setting up mechanical operation of the secondaries - this is becuase that you actually loose power from under 3k rpm on full throttle, and gain power from there until where the secondaries would normally be fully open - 4.5-5krpm at Lucky stated. The lower then higher power would certainly accelerate the feeling of a kick due to the power ramp 3-4.5k compared to stock.
				Posted: Sun May 19, 2013 2:07 am
				by richrx
				Thats a great reply,
 Think the cars probably just fine
 and im looking for more than the cars got due to being more used to turbo rotaries and big engined modern cars...
The cars flooded just now, should be out in it tomorrow though
				Posted: Thu May 23, 2013 5:55 pm
				by Dan Dillinger
				Hi Rich,
Welcome to the forum! You are local to me too.. I'm in West Lothian!
I'm actually breaking a series 3 FB rx7 the same colour as yours!
If you need any parts, give me a shout!
Dan
				Posted: Wed Jun 05, 2013 8:01 pm
				by richrx
				Hi dan,
Fantastic to know, what have you got or not got? Seems an idea to collect a few bits for the future
 even email me at
richardrx@hotmail.com.
				Posted: Fri Jun 07, 2013 4:27 pm
				by richrx
				Hi
So after a wash and polish I thought id post up some of the work I'll be needing to do on the cars bodywork. Its certainly not bad overall, but some thoughts and opinions on the bits that require attention, maybe some pointers would help
This is the worst bit, the rust is on the offside behind the bump strip..
						- Screenshot_2013-06-06-11-26-05.png (532.98 KiB) Viewed 5404 times
Also the headlight wont sit flush, I've reset it using the arm inside the bay but it just wont retract that last few mm.
Also a bit of rust starting on the sunroof...
The mazda badges have been swaped for non standard items
And finally one of the rear light cobvers appears to be slightly smoked and the other clear, not sure how clear that is in the photos though.
				Posted: Fri Jun 07, 2013 4:31 pm
				by richrx
				Photos of the rear... oh ideally the GB sticker to go too...
				Posted: Fri Jun 07, 2013 10:48 pm
				Thermal reactor still fitted? This will choke the life out of it. Huge gains to be made fitting headers.
				Posted: Fri Jun 07, 2013 11:04 pm
				by richrx
				Yep the cars about as standard as you could ever get. Which I really like, not sure whether to fit an exhaust, electric fan and carb or keep it original....
