KIMI - Series 2/3 Hybrid
Has thanked: 505 times
Been thanked: 451 times
Re: KIMI - Series 2/3 Hybrid
Wheelarch before:
Before work 2.JPG (214.8 KiB) Viewed 5841 times
Before work 6.JPG (277.35 KiB) Viewed 5841 times
Derusting:
Initail prep 3.JPG (284.16 KiB) Viewed 5841 times
Initail prep 4.JPG (229.06 KiB) Viewed 5841 times
Initail prep 5.JPG (261.25 KiB) Viewed 5841 times
Initail prep 14.JPG (252.97 KiB) Viewed 5841 times
POR15 pre-treatment (de-grease and acid etch):
Final acid etch 2.JPG (207.36 KiB) Viewed 5841 times
Final acid etch 3.JPG (235.06 KiB) Viewed 5841 times
Final acid etch 6.JPG (203.21 KiB) Viewed 5841 times
Final acid etch 8.JPG (219.36 KiB) Viewed 5841 times
POR15 applied
Offside wheel arch 021.JPG (141.64 KiB) Viewed 5841 times
Offside wheel arch 024.JPG (154.58 KiB) Viewed 5841 times
Offside wheel arch 025.JPG (185.14 KiB) Viewed 5841 times
Offside wheel arch 028.JPG (160.09 KiB) Viewed 5841 times
Offside wheel arch 029.JPG (169.75 KiB) Viewed 5841 times
Offside wheel arch 031.JPG (203.02 KiB) Viewed 5841 times
Rear Axle and Diff:
2014-06-13 11.46.16.jpg (222.31 KiB) Viewed 5840 times
2014-06-13 19.55.01.jpg (193.12 KiB) Viewed 5840 times
2014-06-13 19.55.39.jpg (232.87 KiB) Viewed 5840 times
2017-01-09 14.08.29.jpg (510.9 KiB) Viewed 5840 times
Suspension arms.
Before :shock :o :o
Rear Bush Before.jpg (81.06 KiB) Viewed 5839 times
WIP:
Suspension bolts re-plated using a "Gateros" kit. These were the first few I did, not perfect, but I got better at the process with the later bolts.
2015-01-09 15.29.37.jpg (208.49 KiB) Viewed 5838 times
2015-01-09 15.31.27.jpg (156.73 KiB) Viewed 5838 times
Rear brake calipers:
One before:
DSC_0027 (2).JPG (235.15 KiB) Viewed 5836 times
After Bigred refurb:
Porters2
Has thanked: 112 times
Been thanked: 133 times
Post by Porters2 »
s(c)
Looking bloody brilliant Malcolm 👍
Has thanked: 628 times
Been thanked: 218 times
Far out bro. That is all looking sweeeeeeeet!
Has thanked: 44 times
Good work Malcolm :thumbup:
Thanks guys!
The rear brake stone guards were in a bit of a state, with missing bits and holes. I'm not too proud of the bodge I have made to make them at least functional, but at least they are not easily visible and will do the job.
Before:
2017-04-07 16.57.45.jpg (629.59 KiB) Viewed 1568 times
Aluminium plate cut to size:
2017-08-22 17.15.23.jpg (486.03 KiB) Viewed 1568 times
Replacement parts made. Ali shield pop-rivetted on, stainless steel strip curved around edge, POR 15 and sealant applied:
2020-05-18 19.20.19-1.jpg (168.84 KiB) Viewed 1568 times
Mounted back on the axle:
2019-04-19 13.50.10.jpg (242.84 KiB) Viewed 1568 times
New brake lines installed:
2019-04-20 15.11.35.jpg (289.93 KiB) Viewed 1568 times
