84GSLSE 13BREW Swap build
- DWNUNDR
- Has thanked: 38 times
- Been thanked: 46 times
Re: 84GSLSE 13BREW Swap build
just need some wiring gurus living close in MN and Id be making progress
- DWNUNDR
well havent done too much the last couple of months... still dealing with wiring.. or I should say avoiding it.. but everytime I head out to the shop it hasnt done itself... hahaha so to give myself a little inspiration to keep moving forward I thew the wheels on it and pushed her outside for a looksie at how she sits... I did make a bracket to support the monster tacho (should work)
- DWNUNDR
modified one of my coolant hoses as I didnt like it running in under the plenum and sitting on stuff
- Has thanked: 441 times
- Been thanked: 181 times
- DWNUNDR
Designed and made a little cable bracket for the FD accelerator cable..
Not bad for under an hrs work in solidworks, on the flowjet and a manual drill press..
Those coolant hoses are looking pretty sweet aye. I bet that was satisfying having the throttle cable bracket work out well!
- Has thanked: 232 times
- Been thanked: 276 times
great build this. Nice work on the bracket
How's the wiring coming on, are you close to firing it up yet?
- DWNUNDR
sadly I havent touched the wiring for about 2-3months... it is soooo frustrating... and discouraging... so I havent tried to dive in myself.. Im fine with designing, making, welding, fabricating.. but wiring just stumps me.. I get a mental constipation happening when I try to go to far into it.. hahaha
If I had a bunch of cash Id trailer it to a shop and have them get it to the point of engine bay wiring and firing it up level... then... I can move on to other stuff... it is all pretty much waiting on the wiring to be knocked out....
:x
:x
- DWNUNDR
wiring is being attended to by some local guys bit each week.. so they are now wanting to push to get it running before winter... so 3 of my kids and I started body prep work...
https://imgur.com/a/qQJv2KO
